Results 1 to 4 of 4
Thread: b20/vtec dip stick/tube question
    paint booth
    Default b20/vtec dip stick/tube question
    i have a b20/vtec swap and the dip stick/tube that came with it is way to long. is there any other dip stick and tube i can use?
    earth ????
    b20 dip/s
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    some b20 were like that. if you can take the pan off and get something thats almost the samr sise as the tube,knock it out from inside the block, then install an ls one by tapping it in with 2x4 on it and a hammer as not to mushroom it out.done this b4 alot...
    West palm beach
    the last b20 swap I did had the same issue. I just cut a couple inches off the dip stick and the same amount off the tube, worked perfect...
    NO ADVERTISING
    -IA MANAGEMENT
