Results 1 to 1 of 1
Thread: PSA closeout deals on tirerack hankook ventus 21 evo's
    rockin' the double M's
    l'ville,ga
    Default PSA closeout deals on tirerack hankook ventus 21 evo's
    The Ventus S1 evo is Hankook's Max Performance Summer tire developed for the drivers of sports cars, sporty coupes and high performance sedans. The Ventus S1 evo is designed and built for improved durability by minimizing distortion at high speeds and high temperatures. Like all summer tires, the Ventus S1 evo is not intended to be driven in near-freezing temperatures, through snow or on ice.
    The Ventus S1 evo radials feature Hankook's Highly Dispersible Silica (HDS) compound molded into an asymmetric tread design that features continuous ribs to reduce noise while increasing longitudinal stiffness to enhance braking performance on dry roads. Wide circumferential grooves and large shoulder notches help water flow through the tire's footprint to resist hydroplaning.
    The tire's internal structure includes twin steel belts reinforced by two-ply high-density, spirally wrapped jointless nylon. Additionally, a two-layer rayon carcass that sandwiches a hard sidewall filler between the body cord plies helps resist distortion at high speeds and while cornering.
    use this link to get started...http://www.tirerack.com/tires/tires....=Ventus+S1+evo
    225/45R17 HK VENTUS S1 EVO # 77.00
    225/40R18 HK VENTUS S1 EVO # 89.00
    225/45R18 HK VENTUS S1 EVO # 105.00
    235/40R18 HK VENTUS S1 EVO # 137.00
    245/45R18 HK VENTUS S1 EVO # 99.00
    255/35R18 HK VENTUS S1 EVO # 132.00
    265/35R18 HK VENTUS S1 EVO # 119.00
    275/40R18 HK VENTUS S1 EVO # 109.00
    295/30R18 HK VENTUS S1 EVO # 137.00
    225/35R19 HK VENTUS S1 EVO # 165.00
    245/35R19 HK VENTUS S1 EVO # 139.00
    245/40R19 HK VENTUS S1 EVO # 138.00
    245/45R19 HK VENTUS S1 EVO # 139.00
    255/30R19 HK VENTUS S1 EVO # 79.00
    255/35R19 HK VENTUS S1 EVO # 129.00
    275/35R19 HK VENTUS S1 EVO # 139.00
    275/40R19 HK VENTUS S1 EVO # 99.00
    275/45R19 HK VENTUS S1 EVO # 151.00
    285/30R19 HK VENTUS S1 EVO # 139.00
    245/30R20 HK VENTUS S1 EVO # 189.00
    245/35R20 HK VENTUS S1 EVO # 125.00
    275/30R20 HK VENTUS S1 EVO # 145.00
    285/30R20 HK VENTUS S1 EVO # 138.00
    295/25R20 HK VENTUS S1 EVO # 97.00
    265/30R22 HK VENTUS S1 EVO # 79.00
    295/25R22 HK VENTUS S1 EVO # 154.00
    i just ordered 2 sets...reps damnit
