Results 1 to 23 of 23
Thread: SERVER TOO BUSY
    Don't ya like clowns? Paul's Avatar
    Feb 2001
    Default SERVER TOO BUSY
    lol i changed a setting last week to limit connections and i just got owned by it
    Paul "your bullshit makes the flowers grow"
    Change that shit. It does it to me like every 30 min. Its obnoxious haha
    Lexus GS300
    Feb 2001
    Quote Originally Posted by SL33P3R
    i up'd the connection limit - i think the amount of connections are killing the server giving us those DB errors
    Aug 2001
    Charlotte, NC
    LMAO!!
    '15 Chevy SS
    '16 K7 SXL SWP
    I see you changed the screen or something whenever it does happen. Its not that obnoxious white screen. Not saying the current one is any better or anything
    Lexus GS300
    Hiram, GA
    YEA i HAVENT GOTTEN THAT SHIT 5 OR 5 TIMES ALREADY. TIME TO UPGRADE THE SERVER, NOT DIMISH THE CONNECTIONS.
    Feb 2001
    Quote Originally Posted by BanginJimmy
    want to pay the extra rent for upgrade
    Kennesaw, GA
    If you got rid of all of nermins accounts, we wouldnt have any problems, and this site would run alot faster too
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Does IA use mysql or microsoft sql server?
    Feb 2001
    mysql is there a microsoft sql option for VBulletin?
    the county
    good thing, cause i couldn't get on for like 2 days cause it kept saying it was "too busy"
    Feb 2001
    well i set it too 1500 connections and just up'd it... i know since i capped it i haven't seen a DB connection error.
    I believe vbulletin will work with any standard SQL database, although ive generally heard of better success with mysql.
    Columbus, OH
    Paul, please tell cgEvan he's a dumbass, kthnks
    CHASE ->>>
    WHAT MATTERS
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Quote Originally Posted by Paul
    i dont know if yall have MySQLi but if its not yall should enable the improved SQL engine... I don't think it was out when IA launched on the old software... but on the new version its on there
    just go to the config.php and edit this section
    Quote Originally Posted by config.php
    // ****** MySQLI OPTIONS *****
    // When using MySQL 4.1+, MySQLi should be used to connect to the database.
    // If you need to set the default connection charset because your database
    // is using a charset other than latin1, you can set the charset here.
    // If you don't set the charset to be the same as your database, you
    // may receive collation errors. Ignore this setting unless you
    // are sure you need to use it.
    // $config['Mysqli']['charset'] = 'utf8';
    // Optionally, PHP can be instructed to set connection parameters by reading from the
    // file named in 'ini_file'. Please use a full path to the file.
    // Example:
    // $config['Mysqli']['ini_file'] = 'c:\program files\MySQL\MySQL Server 4.1\my.ini';
    $config['Mysqli']['ini_file'] = '';
    // Image Processing Options
    // Images that exceed either dimension below will not be resized by vBulletin. If you need to resize larger images, alter these settings.
    $config['Misc']['maxwidth'] = 2592;
    $config['Misc']['maxheight'] = 1944;
    why don't you make it members only?
    - IA Mgmt
    Advan Kid
    Paul I got it again...
    Oh and do you still own a Green and Black golf. Lol I saw one in PTC and was like what the fuck. That Pauls car.
    GTR and TDS are buds!
    I think IA is racist against white folk. Look @ the line-up...
    Julio - Dominician, BobbyFresh - Afro-Americian,Brett - Old,Scotsman - Scottish,AnthonyF - Itallian,GKtib - yellow,Quickdodge - gangsta ninja,Ren - Vag-tastic,911SC - Ghey
    Not one whitey among them!!!!!!
    Feb 2001
    Quote Originally Posted by gtrmonkey
    na Scott Parker owns it
    paul..give me the green light.
    Douchebag Ed's Avatar
    Smyrna, GA
    h4x
    Feb 2001
    which one the too busy or SQL DB error?
    Advan Kid
    The too busy
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    dude I keep getting the too busy shit..... atleast 3 times today
