- Funky Headlight
Funky Headlight
Alright I'm on my second set of HIDs... after you turn them on and they get up to running temp. the passenger headlight cuts off. If you turn them back off and back on again, it will usually stay on then Sometimes you have to do the process again for it to finally stay on (this process finally led to the demise of my first set of HIDs where I blew a bulb because I would have to cut them on and off several times before it would come on again). I've tried grounding it to the frame so it's not using the OEM pigtail and it still does the same thing. I know it's not the ballast or the bulb or anything because I had the same problem with both HID kits.
Anyone have any ideas where to start now?
- Funky Headlight
- You may not post replies
- You may not edit your posts
Forum Rules
