Thread: torque help
    Default torque help
    real quick, what would be better:
    1. Engine torque bar damper kit(the kind that mounts to block and strut tower)
    2. Urethane motor mounts with 70A rating
    Southside Ridin HATCH
    Good mounts should be fine? What you running?
    O and i had a friend use this Window foam stuff!!! Its foam and dries SO HARD!!!
    ^ just put it on your Rear mount in the back..... should be really stiff!! It worked great for him!!
    supercharged set up, i figure they are both going to do same thing, just wanted to know what better invesment is
    If your running stock mounts now.. The BEST investment is After market Mounts.
    YEAH! bRiAnMcIvIcS's Avatar
    I suggest getting the innovative 60a mounts anything more than that will vibrate the whole interior of your car like crazy...No bueno. Very annoying.
    ok, mounts it is, thanks guys
