Thread: Top 10 Photography Composition Rules
    Default Top 10 Photography Composition Rules
    Rule of Thirds
    The most important elements (the horizon and
    the haystack) are placed on or around the lines
    and points of intersection. Image by Cayusa.
    Imagine that your image is divided into nine equal segments
    by two vertical and two horizontal lines. Try to position the
    most important elements in your scene along these lines, or
    at the points where they intersect. Doing so will add balance
    and interest to your photo. Some cameras even offer an option
    to superimpose a rule of thirds grid over the LCD screen, making
    it even easier to use.
    Balancing Elements
    The figure in this scene is balanced
    by the rocks in the foreground. Image
    by manipula.
    Placing your main subject off-centre, as with the rule of
    thirds, creates a more interesting photo, but it can leave
    a void in the scene which can make it feel empty. You
    should balance the 'weight' of your subject by including
    another object of lesser importance to fill the space.
    Leading Lines
    The line of the chain leads the eye
    into the scene towards the boat.
    When we look at a photo our eye is naturally drawn
    along lines. By thinking about how you place lines in
    your composition, you can affect the way we view
    the image, pulling us into the picture, towards the
    subject, or on a journey 'through' the scene. There
    are many different types of line - straight, diagonal,
    curvy, zigzag, radial etc - and each can be used to
    enhance our photo's composition.
    Symmetry and Patterns
    The symmetry of this scene is broken by
    the uneven staircase and the closed
    curtain. Image by B G.
    We are surrounded by symmetry and patterns,
    both natural and man-made, and they can make
    for very eye-catching compositions, particularly
    in situations where they are not expected.
    Another great way to use them is to break the
    symmetry or pattern in some way, introducing
    tension and a focal point to the scene.
    Viewpoint
    The unusual viewpoint of this photo
    makes for an interesting composition.
    Image by dollie_mixtures.
    Before photographing your subject, take time to think
    about where you will shoot it from. Our viewpoint has
    a massive impact on the composition of our photo,
    and as a result it can greatly affect the message that
    the shot conveys. Rather than just shooting from eye
    level, consider photographing from high above, down
    at ground level, from the side, from the back, from
    a long way away, from very close up, and so on.
    Background
    The plain background in this composition
    ensures nothing distracts from the woman's
    face. Image by Triotex.
    How many times have you taken what you thought
    would be a great shot, only to find that the final
    image lacks impact because the subject blends into
    a busy background? The human eye is excellent at
    distinguishing between different elements in a scene,
    whereas a camera has a tendency to flatten the
    foreground and background, and this can often ruin
    an otherwise great photo. Thankfully this problem is
    usually easy to overcome at the time of shooting - look
    around for a plain and unobtrusive background and
    compose your shot so that it doesn't distract or detract
    from the subject.
    Create Depth
    The tree stump in the foreground adds depth
    to what might otherwise be a flat scene.
    Image by spodzone.
    Because photography is a two-dimensional medium,
    we have to choose our composition carefully to conveys
    the sense of depth that was present in the actual scene.
    You can create depth in a photo by including objects in
    the foreground, middle ground and background. Another
    useful composition technique is overlapping, where you
    deliberately partially obscure one object with another.
    The human eye naturally recognises these layers and
    mentally separates them out, creating an image with
    more depth.
    Framing
    The archway in this scene provides a natural
    frame for the ruin in the background.
    Image by Les Bessant.
    The world is full of objects which make perfect natural
    frames, such as trees, archways and holes. By placing
    these around the edge of the composition you help to
    isolate the main subject from the outside world. The
    result is a more focussed image which draws your eye
    naturally to the main point of interest.
    Cropping
    By cropping in tightly on the eye, the viewer's
    attention is focussed fully on it. Image
    by m00by.
    Often a photo will lack impact because the main subject
    is so small it becomes lost among the clutter of its
    surroundings. By cropping tight around the subject you
    eliminate the background 'noise', ensuring the subject
    gets the viewer's undivided attention.
    Experimentation
    With the dawn of the digital age in photography we no longer have to worry about film processing costs or running out of shots. As a result, experimenting with our photos' composition has become a real possibility; we can fire off tons of shots and delete the unwanted ones later at absolutely no extra cost. Take advantage of this fact and experiment with your composition - you never know whether an idea will work until you try it.
    Composition in photography is far from a science, and as a result all of the 'rules' above should be taken with a pinch of salt. If they don't work in your scene, ignore them; if you find a great composition that contradicts them, then go ahead and shoot it anyway. But they can often prove to be spot on, and are worth at least considering whenever you are out and about with your camera.
    Reference:
    http://www.amateursnapper.com/photog...position-rules
    Lots of useful pieces of information! reps!
    Da Nastyist Whipz Member #9
    X-Auslese
    nice post
    A+
    Kennesaw, GA
    good post!
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    still searching! Hondatwin23's Avatar
    Atlanta\Lithonia
    highly useful
    http://twitter.com/LEGEND_STATUS
    1997 w/1999 civic w/ Built GSR...FS/FT
    Awesome post
