Thread: BMW AMP Bypass
    E46_ZSP rude_lude911's Avatar
    Macon, Georgia, United States
    Default BMW AMP Bypass
    does anyone here kno how to bypass the BMW factory amp. My car's a 97' 328i and i fully installed a new Panasonic radio in it. It works prefectly just no sound. The speakers come on if I switch to AM or FM stations but not CD mode. If anyone had this problem and fixed it. Please inform me on how to. Thanx
    Funk E. Fresh okra1981's Avatar
    West
    I know there must be a module that you can buy, I've been searching some sites, lazily, and haven't come up with anything just yet.
    I know that you can always bypass any factory system by running new speaker wires to new speakers, and this being an eleven year old car, that might not be a bad idea. I never worked on many BMWs when I was installing in MS though, it was kind of a poor area of the state and we didn't see many new or used luxury cars and there were no dealerships near us.
    I'll tell you though, some of the Bose integration units and others that I've used haven't always worked all that well. Even in my brother's Avalon, it never really integrated with the system all that well and would go static every now and then. I almost always preferred replacing everything. I can't tell you how I feared seeing the dreaded Bose emblem in all of those stupid cars, a big hassle. Just thank yourself that you didn't buy a Cadillac Avante.
    Some say that his politics are terrifying, and that he once punched a horse to the ground...
    you dont have to bypass it..there is a white wire(factory amplifier turn on) on the factory radio harness..it needs ignition(red) or remote output(blue/white) from your panasonic.THE REASON IT ONLY PLAYS ON AM.FM IS BECAUSE YOU NEED TO USE THE REMOTE TURN ON WIRE(BLUE/WHITE)NOT THE SOLID BLUE ANTENNA WIRE..THE SOLID BLUE WIRE ONLY OUTPUTS 12V WHEN THE RADIO MODE IS ON(TO CONTROL A POWER ANTENNA)THE BLUE/WHITE IS YOUR REMOTE TURN ON LEAD,IT SUPPLIES 12VOLTS AS LONG AS THE UNIT IS ON ..IN ANY MODE
    Quote Originally Posted by b@d @pple
    From the master installer himself!
    X2
    thanx to all for the support. AND IT WORKED!!!!
    West
    Oh, I was thinking that it acted like a Bose amp, my bad. It's been a while since I've done anything professional and I'm a little cobwebby.
    Fake Suburban Environment
    BMW is 99.9% of the time Blue to Blue/White
    NEVER bypass the OEM amp if you are just installing a head unit. Would have to mess around making custom crossovers and such.
    1997 M3/4/5
    2004 X4 4.4i
    1987 325iS 24V 6speed
