Results 1 to 26 of 26
Thread: Boosting with a valve cover oil leak
    Stay Humble
    WV
    Default Boosting with a valve cover oil leak
    I am about to run about 7 t0 8lbs of boost but have a very minimal valve cover leak. would it be safe to run boost now and fix soon after or just go ahead and fix?
    FIX IT. THE VALVE COVER GASKET KIT IS CHEAP AND EASY TO DO
    Why not just fix the problem for $20 ? Doesn't make sense to take a risk if you have an option...
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by aaronfelipe
    It takes 15 minutes.
    -Ant.
    The Carbon Fibered R6
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    fix what is wrong first...otherwise you are gonna end up with alot of other problems...
    Stay Humble
    WV
    ok.....i need to tske off the head and just remove the gasket and replace?
    correct?
    Chattanooga,TN
    edit cause teh sammich beat me to it
    UH NO
    JUST REMOVE THE VALVE COVER...UVE NEVER REPLACED A VALVE COVER? ITS SIMPLE. U REPLACE THE VALVE COVER GASKET AND THE SPARK PLUG GROMMETS AND W/E ELSE IS IN THE KIT. ITS A STRAIGHT FORWARD JOB. EVEN I CAN DO IT
    Stay Humble
    WV
    HOLY DAMN!!!!!
    i meant head leak not valve cover....shiiiiiiiiiiiiiiiitttttt lol.
    so from the top haha.
    how do i do the head gasket
    Quote Originally Posted by chaseamundo
    HOLY DAMN!!!!!
    DEFINITELY GET THAT DONE BEFORE BOOSTING. I BET UR BLOCK LOOKS LIKE A OIL FACTORY.
    Augusta Ga
    HOLY DAMN!!!!!
    i guarantee it isnt his head leaking ... i bet he noticed some oil from the vtec solenoid leaking and it looks like its coming out between the head and block ....
    93 sol Si
    95 sol S
    95 sol Si
    ALL CAPS JITB's Avatar
    Quote Originally Posted by 1SOL2NV
    ive never seen a headgasket leak like hes describing either...lol
    revolution big mac's Avatar
    yeah man because when you hit boost and vtec oil will just pour out
    Chattanooga,TN
    unless you trust yourself reading a manual/ stuff on the net....I would let a professional do a head gasket...
    Stay Humble
    WV
    hahaha i def dont trust myself. and its not a huuuuugggeeeee leak lol. but def somthin that is noticed.
    Chattanooga,TN
    it will be more than huge if you dont fix it before boosting
    exactly. dont boost nothign until the engine is 100% sound
    DUH-KYOO-LUHHH
    fix it or you will have just accidentally your whole motor.
    what the hell kinda question is this anyways? if theres a problem before turboing a car (or any other major mod for that matter...), why would you NOT fix it ahead of time?
    hustler ksniperfox's Avatar
    lawrenceville
    car should be in mechanical tip top shape before you boost it.
    Stay Humble
    WV
    OI
    ok....well ill just go ahead and get that taken care of. thanks for the help guys...
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    please make sure that it isn't the vtec solenoid leaking. I have replace many b series hg's and its quite simple, I got too where I could take the head off in like 30 mins or less, but putting it back on is alittle different. Might want to get ARP Heads studs tooo.
    West palm beach
    so you go through all the work of boosting a honda and don't wanna fix a simple oil leak ?
    still searching! Hondatwin23's Avatar
    Atlanta\Lithonia
    please lets stop the senseless oily engine bays in america.
    everytime this happens a small japanese family dies....................
    Attached Thumbnails Attached Thumbnails -dsc01220-jpg
    http://twitter.com/LEGEND_STATUS
    1997 w/1999 civic w/ Built GSR...FS/FT
    paint booth
    wipe everything off and clean with degreaser before taking your head off. like someone else said "its probably the vtec solinoid leaking" or the distributor seal. my b16 had oil in the corner all the time and i thought the same thing but turned out to be the distributor seal.
    Stay Humble
    WV
    hmmmok....how do i know if its the vtec solenoid?
    and im def fixing it before boost
    hmm, i should probably check all my gaskets. I credits my dirty engine to "gunk" but it looks like a less serious version of that Picture. lol.
