Results 1 to 5 of 5
Thread: 2009 Suspension Help
    mech
    Default 2009 Suspension Help
    I'm sure there are plenty of suspension experts in here so I have a question for you. I have a 2009 Hyundai Sonata V6. The car has plenty of power but it just drives like a boat. I bought a set of Eibach Springs for it but that only lowered it and did not provide any better spring rate. Here's the question.
    Does anyone have any ideas on custom spring venders that can make springs per my specs?
    I've looked online and there are no "racing" type springs for the car and I'd really like to get this thing driving right.
    thanks,
    Phil
    2009 Sonata
    2008 SI
    http://www.honda16v.com
    2006 Lexus IS350
    2001 Lexus IS300 SBM
    How far did they lower and are you going to keep the factory struts? Lowered on factory struts does not equal good handling. Struts and tire upgrade is where I saw the most significant changes. Springs were good for visual height but adjustable struts and softer grippier tires.
    mech
    redciv1, you are absolutely right. So far I have upgraded to 17X7 wheels with 255/50 tires.
    The springs lowered the car about 1 inch, looks better but as you have figured out, no better handling.
    I'll be upgrading the struts next but I'm thinking that the springs do not provide enough support. If I put anything in the trunk it SAGSSSSS bad.
    thanks for the info,
    Phil
    2009 Sonata
    2008 SI
    2006 Lexus IS350
    turbos
    Look into other toyotas that share the same suspension and may have larger diameter anti-roll bars.
    If you dont mind I would like to see a pic of this lowered Van
    TOO BIG
    mech
    Quote Originally Posted by seanrg1116
    Seanrg1116,
    Sorry to disappoint but this is a car not a minivan.
    Sonata BEFORE Springs
    I'll try to get some pics up for after the springs were installed.
    thanks for the info.
    Phil
    2009 Sonata V6
    2008 SI
    2006 Lexus IS350
