Results 1 to 1 of 1
Thread: vtec problem!!!!
    Exclamation vtec problem!!!!
    just finished b16a swap in 91 hatch vtec does not engage at all triple checked all wires to the ecu and all are correct if you touch a power wire to the solinoid you can hear it click i know for a fact vtec works because the swap was in another car of mine does anyone ahve any suggestions on what it could be i have a pr3 ecu if i am not mistaking the rev limit should be 8 grand right now it hits about 75 or 76 hundred forgot the car has a crx dash in it and i noticed today when i pulled the cluster out to make sure the speedodmeter was hooked up that there were some wires clipped and some were solidered together could a wire be cut in one of these two harnesses
