Results 1 to 15 of 15
Thread: Shake Shake Shake!!!
    I don't pull out... E=MC˛'s Avatar
    Where we like our sisters...
    Default Shake Shake Shake!!!
    Car: 1993 Nissan Sentra
    2.0 / 5 Speed
    My problem is around 25mph my car starts to shake and continues to around 55ish. ONLY does it when accelerating. The harder i push the gas the worse it does it. I got the tires balanced out 3 days ago and were perfectly fine.
    Any ideas?
    any more description
    i'm a got dang wallaby!!
    wheel bearing, bushings, engine running problems, mounts, loose bolts.... etc etc
    Alpharetta, Ga
    you need a axle fool...
    The G Spot Hero
    Alpharetta, Ga
    JM = the fails....
    The G Spot Hero
    Alpharetta, Ga
    Quote Originally Posted by DirtyMechanic
    JM = the fails....
    i retract this since JM AIM'd me this...
    http://images.google.com/images?hl=e...sasaki&spell=1
    The G Spot Hero
    Duluth, GA
    x2 on axles
    the county
    word.
    does it quit after you get going so fast?
    95 teggy for parts DaRussian's Avatar
    check if ur wheels are loose or not.
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    it stops when i get to about 60. wheels are not loose.
    Loganville
    my car did the same thing, but I changed my axles and the shake went away
    Ballin' on a Budget
    axles it is.
    thanks guys.
    The crack
    Damn Scott maybe you should just keep it steady at 60 that should fix it
    IA's Pedo-cord tdurr's Avatar
    Fayco
    Quote Originally Posted by Okie_doke.
    thats wut i would do
    Save ur engines!
    Columbus
    axles....i had the same problem i had to replace one then it stopped
    Little Talon That Could...
