Results 1 to 3 of 3
Thread: Sunroof help
    The crack
    Default Sunroof help
    Has anyone that has/had a civic with a sunroof ever had a problem with it leaking? I mean it doesn't leak from the sunroof and I've heard they have drain tubes that get clogged, is this true? If so how do i go about cleaning them? My driver side floor board gets wet when my car just sits in the rain and my trunk on the driverside drips too but the rubber is all good and sealed, WTF. Any help would be appreciated reps for anyone that can help
    Its probably your drain tubes are clogged. If you open the roof, the front 2 corners you can see a small hole in the body, these are the front drains. Best bet is to used compressed air to blow them out. The rear drains are difficult to get to without a very long nozzled blow gun or removing the headliner. You could always find the end of the drains under the car and blow backward through them.
    The crack
    Thanks alot man I'll give it a shot, reps
