Thread: FS- Bosch WBO2 sensor $50
    wherever
    Default FS- Bosch WBO2 sensor $50
    Bought this to replace the WBO2 on my Hydra 2.17... found out it's not compatible...but will work with Hydra 2.5. Can be used on various custom wideband setups.
    Bosch #15401 (L2H2)
    Has maybe 300mi on it. I had to splice it onto the Hydra WBO2 harness (not included) so you'll get it with cut wires and the original connector that same on it...sorry.
    $50
    02' Miata
    K24/K20 love
    Hmm if itworks with a ZEITRONIXs wideband Ill buy it.
    wherever
    Quote Originally Posted by IloveLindaT
    What WBO2 does it currently use?
    02' Miata
    Bender A. Rodriguez
    Macon
    Damn Mike, I was hoping that would work. I was following your thread on Miataturbo. If you find any that are compatible with the 2.6 let me know. I'm overheating the one on Thunder over 15psi but my AEM stays true.
    Ryan Reynolds
    wherever
    well, if the one from the 2.5 will work on the 2.6...then this one will work. What is the #stamped on the wbo2 that came with yours?
    02' Miata
    Bender A. Rodriguez
    Macon
    Don't know, I'll have to check. Ours is the 2.6 as well and I want it to be able to read on boost but it overheats and pegs lean. I know its the sensor since its only a few inches from the AEM sensor and it always reads true.
    Ryan Reynolds
    WazzySpace.com wazzyatl's Avatar
    N. Atlanta
    will this work with an AEM uego gauge setup
