Thread: LED/BARCODE PIMP WATCH 200.00
    THE MAN pimp06's Avatar
    Default LED/BARCODE PIMP WATCH 200.00
    For an LED watch that looks like no other, it has to be Barcode. Featuring large, easy to see LEDs and a solid stainless steel strap, this design is sure to turn heads and make your friends envious.
    The custom designed strap achieves a perfect balance with the case, both featuring strong grooves, the tapered edges of the case meeting the strap neatly.
    The time can be read easily with a touch of the button. The first two columns show hours; in column 1 each light equals 5 hours, in column 2 each light equals 1 hour. The second two columns show minutes; in column 3 each light equals 10 minutes, in column 4 each light equals 1 minute.
    Barcode also has a date mode, the first two columns showing the month, the second two columns showing the day. For detailed product information a pdf instruction manual is available to download below.
    Equipped with a light up function, the lights automatically animate every minute from 6 pm to 1 am and every minute for 12 minutes after the time button is pressed between 1 am and 6 pm.
    A strong and well made design and available with white or multi-colored LEDs, this is a time piece you will love.
    Displays the time
    Date and day mode
    AM/PM and 12/24 modes
    Light-up feature
    Maximum wrist size: 215 mm (approx.)
    Case Dimensions: 28 mm x 57 mm x 13 mm
    Weight: 140 grams
    Water resistance: 3ATM
    English instructions
    Attached Thumbnails Attached Thumbnails -11-jpg   -barcode-jpg
    You need to post pictures or this will be closed.
    You also need to fix that signature. Waaaay too big. Lose one of those pics, please. Later, QD.
    Sandy Springs
    How the fawk you supposed to read that thing....
    And nope, those won't work. You need REAL pics.
    Sandy Springs
    The entire description is copy and paste....
    fuck that i have to add and shit to tell time? why dont i just wear an abacus on my wrist
    LOCKED
