Thread: IDLE AIR CONTROL VALVE
    F.A.N.A.T.I.C. primespark22's Avatar
    Default IDLE AIR CONTROL VALVE
    what would be the signs of it going bad or what are the effects if it is bad,my car car is out of safe mode yet i cant get past 5k rpms and alot of people are saying that this might be why,??
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    Unpainted EM1 Zhu's Avatar
    umm well for me, the check engine light kicked on and I noticed idle rpms were tons loer and led to it being easier to stall... but then I cleaned it out and it was all good.
    I doubt that's the solution to your problem because the name "idle" in IACV suggests that it only messes with your idle... but I could be wrong.
    WTB: Driver's Side Sunvisor for 96-00 Civic
    West palm beach
    signs of bad iacv
    Idle RPM too high
    Idle fluctuating wildly
    Idle RPM too low and/or erratic
    Idle fluctuating when loads occur to the engine
    Fast idle too low for cold starts
    NO ADVERTISING
    -IA MANAGEMENT
    ok so ill give it a good clean, but this wouldnt be causing the problem right?
    Quote Originally Posted by primespark22
    nope
    Quote Originally Posted by punkr6
    signs of bad iacv
    Idle RPM too high
    also bad/jerky light throttle cruising.
    to the op:
    is this a chipped ecu w/ a launch control at 5k? if so and you don't have a cel the speed sensor is bad, but it still communicates diagnostic voltage to the ecu without communicating any speed voltage. that'll cause it to not throw a cel, but will also tell the ecu that you are standing still even though you are rolling=hitting the launch limiter.
    i think your right, cause thats what my car is doing .. hmm maybe a little cleaning wouldn't hurt.. 8D thanks
    /Oo ___A___ oO\
    |=_/_______\_=|
    are b series iacv interchangeable or not and how bout d series
    West palm beach
    b-series yes...
    NO ADVERTISING
    -IA MANAGEMENT
    ok thanks dude..........+1
    my momma's house
    SEARCHING FTMFW!!! I was itching to blurt the most obnoxious thread title to get fast help, but I chilled for a second, meandered through my many flame memories, and almost like a wet titty in a KY wrestling match... SSCCHMMAAACKKKKKK!!!! THE SEARCH TAB!!! This ingenious creation, spawned by Al Gore The Internet God, himself.
    But seriously... I'm pattin' my own back for searching. An essential skill that seemingly is not easily attained by many young IA'ers, such as myself. My car has been a bigger pain in my back than you could imagine, and now, becasue I SEARCHED, I'm almost positive my IACV is the culprit of my phacked up idle.
    Good Day.
    Trend settin'
