Results 1 to 10 of 10
Thread: CEL for my Hatch Please! help
    Rice Rice Vtec
    Default CEL for my Hatch Please! help
    ive been tryna figure out what can be the problem! but then seem to not be able to check the CEL!
    for some reason when i plug in the Wire to chek the CEL it wont BLINK! it'll just stay on and it wont make no move at all!
    okay so as of 3/23/09 i just checked my IACV and when i UNPLUGGED THE SENSOR IT WONT IDLE NO MORE! But then when i PLUG it back in it IDLES Up and Down!
    does this mean my IACV is bad or no?
    please respond
    95 Civic EX-Traded
    93 Civic CX -Sold
    93 Nissan Altim-Sold
    95 Civic CX- RIGHT NOW!
    Team Korupshun DamnDisLaOsBoY's Avatar
    Lawrenceville, Ga
    does the light go on and off every now and then? to the best of my knowledge, turn the key to the on position and once the CEL is on jump it from there... try spraying the IACV with brake cleaner...
    Rice Rice Vtec
    well, yea it goes off wen i turn it to ON! and then wen i start it up it goes back on!
    and it wont blink for nothing at all if im tryna check the CEL on that plug by the ECU!
    but then my cousin told me to try to spray it but then i wasnt sure!
    Quote Originally Posted by DamnDisLaOsBoY
    95 Civic EX-Traded
    93 Civic CX -Sold
    All Motor BlackDubs's Avatar
    Atlanta,GA
    You can only jump the ECU for codes, if the CEL stays on after its cranked. If you try jumping the ECU without the a CEL being on, then the CEL light will just stay on cause there are no codes.
    Like he said, try taking out the IACV and clean it when some carb or brake cleaner.
    Rice Rice Vtec
    yes i know that! im saying it wont let me jump it for no kinda codes! even if its just turn to ON!
    so iono what it cant be! but then i know wen i unplugg the IACV it idle fine, but then wen i plug it back up it idles roughly up and down! so im not sure if theIACV is bad or not! thats what i know know
    95 Civic EX-Traded
    93 Civic CX -Sold
    you probably burnt the ecu.
    Rice Rice Vtec
    no if i burnt my ecu it wouldnt be able to turn the car over right?
    well, im not sure cause it dont seem like its burnt or nothing!
    95 Civic EX-Traded
    93 Civic CX -Sold
    Rice Rice Vtec
    ttt, need the help guys
    95 Civic EX-Traded
    93 Civic CX -Sold
    if the cel comes on while the engine is running and then you jump it while it's running and doesn't go out then usually a sign of a bad ecu...not always, but most of the time.
    try this...start the car. when the cel comes on stall out the car w/o turning off the key. try jumping it at that point. it'll keep the code stored.
    everytime you switch off the car the cel clears from the temporary memory. when you turn the key back on but engine off all the diagnostics are seeing what they want to see, but once it's running it'll be an item that only operates once the engine is running.
    is this a chipped ecu? there could be something very simple that needs to be corrected.
    Rice Rice Vtec
    its a all stock p06 ECU! no mods or nothing to the car or anything!
    imma have to try my boys ECU out to see if thats the problem!
    CEL is off after the is Turn to ON as soon as the Fuel Stop, but then after car is started, 3 seconds later it comes on! so im nt sure whats wrong with it!
    it also feels like its not getting enough fuel from 1500k-2000k inbetween that it idels if im sittn still in the drive way and wen i drive it on the streets!
    so i have no clue!
    95 Civic EX-Traded
    93 Civic CX -Sold
