Thread: b20b4 w/b16 head oil leak question
    Default b20b4 w/b16 head oil leak question
    Is it normal for there to be a wet spot of oil above the block code looks to be dripping from one corner where the head meets the block just above the block code? its not alot but worries me just wondering if it a valve cover gasket or headgasket or if it just happens with this engine combo or if I can just seal it up around the corner area to stop the leak. And the whole motor only has around 200-300 miles on it.
    Augusta Ga
    its probly the cam seal or vtec solenoid ... i have the same problem ...
    93 sol Si
    95 sol S
    95 sol Si
    Quote Originally Posted by 1SOL2NV
    cam seal
    Senior Member G.C's Avatar
    Forgot
    cam seal
    x2 type it in google. theres a good write up and u can diy
    :idb:
    Duluth, GA
    yeah... cam seal sounds right...seen it many times
    FLOSSIN' MR.EM1's Avatar
    yea same problem cam seal..just get any billet cam seal
