ok i just got done putting my b16a in my 93 civic.....vtec will not pop......i have done everything that i knew and still nothing? just wanting to c if anyone knew of any othere reasons why it would not be working..thanks
 vtec wont pop! help me!!!
<a href="http://www.mybannermaker.com" target="_blank"><img src="http://i.imgur.com/9sjGr.jpg" alt='Create your own banner at mybannermaker.com!' border=0 /></a><br>
				what have you checked? there's alot of things that'll cause vtec not to engage.
cel?
				did you check your vtec fluid?
				lmao daaaaamnOriginally Posted by §treet_§peed
				just fucking with you. did you try your vtec solenoid? maybe the plug is not in or its not hooked up right. your timing might be off? im just throwing random ideas out there. list al the things you have tried.
				also what ecu are you running?
				trace the wires back to the ecu
				Most obvious question... did you let the engine come up to normal operating temperature? VTEC has an idiot-proof feature of not engaging until the engine is warmed up.
				yup yupOriginally Posted by xPhantomSilviax
also check
wires make sure they are going to the right pin on the ecu
oil pressure not enough oil or pressure will stop it from engaging
clean the screen on the solenoid
				ok thanks guys...i have tried changin the pressure switch vtec solenoid....runnin the wires straight to the ecu..checked them 100 times...lol....i have tried everything!! it did pop once but thats it....im lost, is there anything else?
resize pic
				adjust the flux capacitor, lol just fucking with ya. maybe pm vtecidd he knows everything about hondas.
				warm up ur car. then manually engage vtec at idle... ill get you the info on how to do that when i get home. basically you jump the vtec connector. ull know vtec kicked in b/c your idle will be wayy off...
				X2^ on that, and make sure u have no check engine lights, your speedo has to work for vtec to work, and I know someone said check your oil pressure but also just check the level too(low level, lower pressure).....Originally Posted by mikegsr
				check your oil
				http://www.honda-tech.com/showthread.php?t=830163
if that dont get u going u got some serious problems.
				im haveing the same problem in the 95 GSR motor i just dropped in my 94 civic. ive seen so many differnt things people say i have to wire but idk how realiable the info is, can someone tell me since we're on the topic.
				if you have low oil in your continueum transfunctioner it wont pop because of the power that wont be sent to teh vtec from the ecu.
if that doesn't work just burn it and call insurance
				lirl!Originally Posted by Arm&hammer
check and make sure the pins you have going into your ecu are the correct pins, if they are not then it may not be connecting into your ecu which would make it so your VTEC wont engage
				check the screen in the vtec solenoid, mine was not working yesterday and the screen was clogged, also touch a wire to the battery and the connector and see if it clicks..
NO ADVERTISING
-IA MANAGEMENT
				Just by reading the title, Im going to say check your oil..
idk if you checked it or not, not reading any posts.. Got to run..
				sometimes u have to clean ur Vtec solenoid!
95 Civic EX-Traded
93 Civic CX -Sold
93 Nissan Altim-Sold
95 Civic CX- RIGHT NOW!
				What you haven't done, is brought it to us to get it fixed
				lol some of you don't realize technically oil can be called vtec fluid. considering that is whats is sprayed on the cam(s) as vtec is engaged.
				thanks for all the help i tried everything and nothing worked hell i even changed the oil pump and still it did not work so i just got rid of the car thanks again.
				Damn....Originally Posted by honda4life
NO ADVERTISING
-IA MANAGEMENT
wtf.
				Damn just read back some lolOriginally Posted by honda4life
VTEC just :idb: you
				Lol....owned by lack of vtec
				hahahahahahaOriginally Posted by Hondatwin23
				WOW simple as that vtec no work = sell that bishh LOL
/Oo ___A___ oO\|=_/_______\_=|
				What about your knock sensor
92 mx3
				1. Check the wiring
2. Check the soleniod it self, screens and all
3. Check your coolant temp sensors
4. Check your oil level
5. Make sure your speedo works
				Or..
ROFL..you couldn't get vtec to work so u sold the car..hahahhahha
It was probably really simple.
