Thread: FS: L28e, 280z(zx) parts, wheels, engine, & more
    Default FS: L28e, 280z(zx) parts, wheels, engine, & more
    I took pictures of Everything listed below and I wont post pics of them unless you need me too. Please reply with what # you want pics of and I will post them in the following post. All prices are not including shipping (coming from zip 30066), and I do require a 2% Paypal fee. Ill meet halfway on that one. Some stuff is from 280z's, some 280zx's and some off a few of my Fairlady's. The Fairlady specific stuff will be labeled at the beginning. I also labeled how many miles were on each part if I know. Thank you.
    2) (Fairlady) P79 (Complete head /w 'F' grind cam) Head, not shaved, no cracks, hottanked, new valve seals, very tight head. 98,000 km ( 60k miles) - $100
    3) (Fairlady) complete stock Nichira exhaust from 280ZX, no exahust manifold but everything after that, cat, post cat, exhaust, tip. - $30
    5) (Fairlady) sun visors pair in silver with all Japanese writing on warning labels. No rips or tears, fabric is little loose though - $50
    6) (Fairlady) L28e 280zx Air Flow Meter /w sticker #A31-622 420 2602 L28 JECS (Fits all 79-83 280zx I believe) 60k miles - $50
    7) 280zx fuel rail /w injectors, will sell just injectors for same price to save on shipping, comes with the plastic housings too 60k miles - $60/set of 6
    8) 280zx white plastic fan /w clutch 60k miles- $30
    9.) Nissan Leather tool pouch. Tools are rusty except wheel chokes. 2 screw drivers, 1 tire lug wrench, 2-3 open ended box wrenches, 1 misc red metal bar(i have pic of it), 2 wheel chokes (one still in bag! unopened), 1 leather pouch in great condition, I think I have the jack too - $40/all
    10.) BWC Blue plug wire set /w coil wire also. 60k or less - $15
    11.) L28e coil pack 60k - $10
    12.) 280zx Intake manifold, webbed, with TB and ALL sensors,idle stuff, ect, fuel rail not included b/c listed seperate but will discount if purchased together 60k miles - $75obo
    13.) 280zx starter 60k miles- $20obo
    14.) 280zx radiator in great condition 60k miles - $45
    15.) 4spd transmission, no shifter, unknown mileage but had parts paint on it stating it was Good, shifts smooth through all gears - $20
    16.) 5spd 1982 280zx non-turbo transmission /w 80k miles, shifter, shifter knob, TO bearing, 2 clutch forks (one is from 300zx I believe(upgrade?), very clean smooth transmission - $175
    17.) 280zx driveshaft 60k miles - $30
    18.) 280zx stock blue airbox /w black plastic parts - $15obo
    19.) 280zx vacuum type distributor /w ign module 60k miles - $30obo
    20) 280zx Alternator from 79' 60k miles or less (tested and works perfectly) - $45
    21) 82 Degree thermostat, new l28e cap/rotor 0 miles, 60k miles o2 sensor(the one in the exhaust manifold) for 280zx single wire, new oil filter, 6 gently used NGK-R BCPR6E11 plugs, 15k miles, 6 New NGK B6ES11 plugs, -$offers on each
    22) Square port 6-3-2 Headers with 3bolt flanges, No rust, No o2 bung, No cracks, Perfect condition - $200
    23) Original Speedstar (SSR) MK-III 14x7 wheels. NOT KNOCK OFFs, Refinished a while ago, polishing could use a quick once over to make super show quality. New longer SS bolt hardware, one piece wheels but possibly two piece before, looks like they might have been welded up and sealed professionally but I dont know the history of these wheels. gold centers, polished double lip, no valve stems, inside barrels cleaned up also, no tires, 4x114.3, 10lbs a piece (SUPER light), wheels only no cracks, no bends, no BS, comes with (2) 5mm spacers also. Get something different than those Mesh wheels everyone is selling - $900
    24) (Fairlady) Fairlady280z emblem from trunk, Square Nissan Emblem, Hood Z emblem, and a SUPER SUPER RARE center console badge that states "Special Edition Import Car of the Year" (I have only seen a few forums posts with this even mentioned and not even any pics. All 4 - $200
    Red Polyurethane bushings below
    27) (2) pairs of Bump Stops for Front and Rear (#14-1301) - $25 for all 4
    (1) pack of 2 Tie Rod End Boots (#19-1711) - $5
    (1) pack of two 23mm front sway bar bushings /w grease (package opened, everything there (#14-1110) - $15
    (1) pair of 280zx front lower control arm bushings (opened package /w 1/2 packet of grease, i might have another unopened thing of grease but there is enough to do the control arms with whats there) (#14-204)- $30
    $50 for all the poly bushings
    Cars: 94'325is/87'325e/79'Fairlady 280Z(X)
    82'528e/84'533i/86'535i/90'300ZX/85'200SX/94'Jimmy
    MADE IN JAPAN nisman's Avatar
    sticks-winder area
    damn this is a datsun guy's heaven.
    good luck with it!
    by the way, on import atlanta you cant type distributor... its gotta be dizzy....
    actually, this might be the first time I have ever typed out the whole word.
    Here is some Eye Candy too of a few of the parts.
    btw, for the P79 head, i have an extra set of springs, and I do have all the lash pads and retainer clips and pieces not shown to go with the head.
    Sorry for the big pics, i thought it would re-size them
    Attached Thumbnails Attached Thumbnails -5spdtrans-jpg   -p79complete-jpg   -ssr1-jpg
    Oct 2003
    pm ME YOUR # I need the injectors for my 76 280z
    You wouldn't happen to have a set of triple sidedrafts, would you?
    no sorry, check ebay or HybridZ.org they are usually letting sets go here and there for $200-$1000 pending condition, setup style, /w or w/o manifolds, and if they need rebuilds.
