Results 1 to 18 of 18
Thread: Replacing Clutch
    Norcross
    Default Replacing Clutch
    When replacing a clutch, are there any hazards, precautions i should take when changing it? i've heard that one should resurface the flywheel... any help would be great, thanks
    the county
    yes, have the flywheel resurfaced, if you don't, you could fuck up the new clutch real quick like.
    you may think the surface is flat, but if its not, then the disk will not be able to grip the surface like it should causing slippage.
    i would also change the pilot and throw out bearing too.
    oh, and it might be easier to drop the motor and tranny out of the car to do it. if you don't, well, have fun. and don't misalign the spline with the disk/flywheel, and dont hit any of the plate things on the pressure plate, bend any of those and it could cause some problems.
    if you bought a brand new clutch, then it will have all the instructions and whatnot.
    nothing major change fluids if it old, resurface flywheel, change pilot bearing and throw out bearing. pretty much all the thing that should be done anyways when replacing a clutch.
    Senior Member G.C's Avatar
    Forgot
    you have to love the clutch. Be one with the clutch and it will magically pop right in.
    :idb:
    Norcross
    another question... is it ok to use the same pressure plate and only replace the clutch disk? or can i get that resurfaced or something?
    I Am, A Stunt Man
    i would just get a new pressure plate if i were you, and wahtch your fingers they might get smashed
    Norcross
    up, is it necessary to replace it tho? or would i run into any problems from it
    Its not 100% necessary but highly highly recommended. I didn't replace the one in my SVT and never had an issue.
    BMW 750iL
    JDM TYTE AnthonyF's Avatar
    Call Clutch Man. They will get you everything you need, come to you, resurface your flywheel at all a GREAT price.
    -Ant.
    The Carbon Fibered R6
    Quote Originally Posted by X-Runner
    most kits come with 1 anyways.
    Yeah most do but I bought mine from the dealer (worked there) and it wasn't offered as a kit.
    BMW 750iL
    true
    the county
    if you get an aftermarket one, then it should come as a kit, and have all the parts that i would suggest changing out.
    1 last thing i forgot check and inspect replace if need be your rear main seal.
    Middle, Ga
    Beat me too it. Suprised no one has already stated that. As a matter of fact, just go ahead and replace the rear main seal regardless. Cheap insurance in the future. With the pressure plate situation, you should be able to buy a clutch kit for not to much more money with everything included besides the flywheel. I myself, would just go ahead and spend the few extra dollars for new stuff instead of using the old pressure plate, etc. Just always remember, do it right the first time and you'll be thankful later.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Norcross
    thanks for all the info guys! i went ahead and got a new pres plate and got my flywheel resurfaced today, should the main seal be bought from the dealer?!
    they are cheap so the dealer is fine.
    what car is it being changed ?
    1991 Acura Integra
    1998 Toyota Corolla
