Thread: 96 civic brake light
    Default 96 civic brake light
    hey i got a 96 civic. the brake lights dont come on when i am braking. Turn signals work and the tailights are on but brake lights dont come on. Im not sure if its a bulb, or the wire. Where should i look for it? Bulb or Wire?
    Southside Ridin HATCH
    bulb. would be in the TAIL LIGHT HOUSING- pop trunk and turn bulb loose out of housing....
    wire- JUST CHECK A FUSE
    the switch at the pedal
    LS Resurrection
    Fulton County, Union City
    check the bulbs, if the bulbs are out then go buy new ones. its 1157 bulbs. if its not the bulbs replace both wires. if its neither check your fuse.
    just bought new bulbs and fuses its not either. how would i check for the switch at the pedal?
    i drive slow im_hung's Avatar
    location, location
    brake switch is bad.
    Duluth, GA
    yes!
    im down right fierce hadouken's Avatar
    you look under to where the pedal is and if you move the pedal you should see where the switch is its like a button where the pedal almost pivots off of it you should be able to see it clearly
    ok its not the pedal, i changed the fuse, bulbs and the switch. what else can it beee?!!?? and now my taillights arent working and i got pulled over for that. the guy at advanced auto part was trying to fix my brake lights but then my taillights went out today. he was messing around with the fuses. What should i do so i dont get pulled over again???
