Thread: TPS
    J.R
    Down South
    Default TPS
    OK well a while back i postd my car was throwing a code 7 throttle body position sensor, well i got a new one my had been removed b4, so i simply unscrewd it and replaced it with the brand new one STILL THROWING THE CODE 7 !HELP!
    J.R
    Down South
    O Ya and i took off the battery for about five min and removed the back'up fuse
    start tracing wires. make sure u have the right connector plugged up.
    \m/>_<\m/ dorin48's Avatar
    Canton
    Do you have a swap and/or did the tps come from a jdm motor?
    J.R
    Down South
    Quote Originally Posted by dorin48
    Naw,no swap,not from JDM motor
    leave the battery plugged, and just take off ecu fuse for a little while i've just recently done mines 2 days ago. unless your having more problems then you think 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    J.R
    Down South
    Im not sure if any other one can fit there, maybe the map sensor but it doesent reach that far so..
    J.R
    Down South
    And only code seven, there are no other codes being thrown
