Results 1 to 15 of 15
Thread: Zen Motors -Subaru Engine Packages,Turbo Kits,Intercoolers,Injectors,MBC's,SMC!
    Default Zen Motors -Subaru Engine Packages,Turbo Kits,Intercoolers,Injectors,MBC's,SMC!
    Engine Package Kits:
    Zen Race 1 (Shortblock Internal Kit 2.5L)
    Zen Price: $1,359.99
    Kit includes the following parts:
    - CP Pistons With Spec'd Ring Set
    - Manley Forged I Beam Rods
    - ACL Rod & Main Bearing Kit
    + Add Subaru Gasket Kit for $289.99
    Zen Race 2 ( Shortblock Internal Kit 2.6L)
    Zen Price: $2799.99
    Kit Includes the following parts:
    - 4340 Billet Steel Crankshaft 83mm Stroke
    - Pro Series Rods with ARP Fasteners
    - CP Pistons
    - 9310 Nickle Carbon Steel Alloy Wrist Pins
    - Ductile Iron Plasma Top Rings, Tapered Second Ring, Low Tension Oil Rings
    Zen Motors Head Package
    Zen Price: 1769.99
    Zen Motors Head Package Includes:
    - GSC Power Division S1, or GSC Power Division S2 Camshafts
    - Full Supertech Valvetrain ( Stainless Intake Intake, Inconnel Exhaust Valves, Springs, Retainers, etc.)
    - ARP Headstuds
    Turbo Kit Specials!!!
    - AMS Performance GT30R / GT35R Turbo Kit
    Call for Price!!!
    - P&L Motorsports GT30R / GT35R Turbo Kit
    Call for Price!!!
    - Crawford Performance GT30R /GT35R Turbo Kit
    Call for Price!!!
    - Ultimate Racing GT30R /GT35R Turbo Kit
    Call for Price!!!
    Front Mount Intercooler Specials!!!
    Perrin Front Mount Intercooler (Standard)
    Zen Price: $1165.95
    Perrin Front Mount Intercooler (Stealth)
    Zen Price: $1265.95
    Injectors Sale!!!
    Deatschwerks Injectors 650cc, 760's, 850's
    Call for Prices!!!
    Manual Boost Controllers!!!
    Hallman Pro Manual Boost Controller
    Zen Price: $105.00
    R Boost Manual Boost Controller
    Zen Price: $49.99
    SMC Meth Injection Kit
    Zen Price: $499.99
    Do you not see something on this thread that interest you? Don't worry, Give me a call I can source out whatever part you are searching for. I have too many items to list on one thread!
    We at Zen Motors LLC. Look forward to serving you with excellent prices, Customer service, and Subaru expertise! We will provide tracking numbers within 24 hours of transaction. If we can not provide tracking info we will notify our customer of the reason as soon as possible. We want to keep you in the loop!
    If you have any questions. Please do not hesitate to ask. You can give me a call here at Zen Motors at 678-587-5404 or you can send me an e-mail at [email protected]
    Tray McConchie
    Sales Manager
    Zen Motors LLC
    Phone: 678.584.5404
    E-Mail: [email protected]
    Website:www.ZenMotorsLLC.com
    Air / Oil Separators
    Crawford AOS
    Drawing on our 35 years of racing knowledge, the Crawford Closed Loop Air/Oil Separator was engineered and designed to keep all the oil where it belongs, inside the motor.
    The Air/Oil Separator solves a simple problem from the manufacturer; it transfers the oil back into the engine via the block not the intake. This not only keeps the vehicle within specs of smog but keeps the oil from coating the tops of the pistons. We all know what that does to any tune you have; it causes detonation, a very bad thing for turbo engines.
    So if you want to keep your engine running consistently and strong for years to come make sure you install a race and street proven product from leaders in the industry. Crawford Performance - RESULTS NOT RUMORS
    FAQ's:
    1. The A/O sep only uses one hose to connect to the intake hose before then turbo. Does the turbo hose draw enough vacuum to make the A/O sep work properly? Does it matter that there is or is not enough vacuum?
    - Our AOS does not need a vacuum source to function properly. If you connect the top line into the intake before the turbo, the resulting vacuum will help the rings to seal better but will have no actual effect on the AOS itself. The vacuum supplied by the intake tube is available 100% of the time as opposed to the vacuum supplied during off throttle situations within the intake manifold.
    2. How does the A/O separate the air and oil?
    - Our AOS uses the time tested and proven “round swirl pot” technology as well as internal baffling to separate air from the oil. This is the industry standard when it comes to air / liquid separators. Our AOS system was engineered and tested on our multiple record setting Crawford Performance Time Attack STI.
    3. How much pressure will the valve covers reach when pushing oil out?
    - There’s a minimal amount of pressure in the valve covers or the crankcase while using a proper ventilating system. The oil that’s pushed out the valve covers happens during high G loads associated with cornering.
    4. The blow by that comes out the heads, that will drain back into the crank case. Will this cause the oil to get contaminated? Isn’t that bad?
    - If the oil coming out of the motor is clean then the oil returning to the motor from the AOS will be clean as well, the AOS does not add anything into the oil system. That being said, if there’s a contaminate in the oil that’s coming out of the motor then it will drain right back into the motor.
    Crawford Air / Oil Separator (Top Mount Intercooler Version)
    Crawford Air / Oil Separator (Front Mount Intercooler Version)
    Crawford Air / Oil Separator (Universal)
    Zen Price $359.99
    IXIZConcept Air / Oil Separator
    The ixizAOSep is compact and full of advance channeling (no media to replace nor deteriorate) to separate air from oil coming from both your crankcase and heads. The drain port will return the oil back to your engine so that you do not loose any oil.
    If you are running high boost you will most likely expose your intake system with oil vapor. This will most likely occur under hard driving. This is due to more compressed air bypassing the rings. This is one reason why there is significant amount of oil loss in between race and oil changes
    IxizAOSep prevents the oil from getting ingested by your turbo and into your intake, which will greatly reduce the efficiency of your engine (reduce octane, engine knock, timing retard,..).
    The system requires no drilling and can easily bolt on to both TMIC and FMIC vehicles. The compact unit can be placed in various locations (depending on your engine setup).
    IXIZ Concept AOS
    Zen Price $295.00
    Tray McConchie
    Sales Manager
    Zen Motors LLC
    Phone: 678.584.5404
    Moroso Oil Pan's
    Moroso High Volume Oil pan helps Fight oil starvation!, It allows you to replace your factory Oil pan, and eliminates the faulty factory Oilpick up tubes.
    Zen Price: $640.00!!!
    Tray McConchie
    Sales Manager
    Zen Motors LLC
    Phone: 678.584.5404
    TurboChargers!!!
    Forced Performance 20G
    Zen Price: $1,159.99
    Forced Performance Green
    Zen Price: $1,459.99
    Forced Performance RED
    Garrett GT3076R
    Zen Price: $1,189.99
    Garrett GT3582R
    Zen Price: $1,299.99
    Forced Performance HTA GT30
    Zen Price: $1,685.00
    Forced Performance HTA GT35
    Tray McConchie
    Sales Manager
    Zen Motors LLC
    Phone: 678.584.5404
    Exhaust Specials:
    Watch a Clip!!! - http://www.youtube.com/watch?v=64H-SHpDpEY
    TurboXS Turboback Exhaust:
    Zen Price: $989.99
    Watch a Clip!!! - http://www.youtube.com/watch?v=5hHvsFqwWsE
    Cobb Tuning Turbo back Exhaust:
    Zen Price: $1,230.00
    Cobb Tuning Catback Exhaust:
    Zen Price: $669.99
    Watch a Clip!!! - http://www.youtube.com/watch?v=JNKFcyg_TZg
    HKS Catback Exhaust / Hipower
    Zen Price: $489.99
    Watch a Clip!!! - http://www.youtube.com/watch?v=znyuhkgyPzk
    HKS Catback Exhaust / Carbon / Hipower
    Zen Price: $699.99
    Titek Downpipe
    Zen Price: $245.00
    Invidia Non Polished Downpipe
    Zen Price: $245.00
    Do these Exhaust Systems, no interest you let me know. I carry a wide variety of Exhaust systems. Agency Power, AMS, Apexi, APS, Blitz, Borla, Buddy Club, Greddy, Perrin, Vibrant Performance, and more!!!
    Zen Motors LLC
    Local Phone:770.904.2868
    2008 Subaru STi Stuff!!!
    Watch a Clip!!! - http://www.youtube.com/watch?v=ZJOg18pgf2w
    Agency Power Exhaust
    Zen Price: $809.99
    Watch a Clip!!! - http://www.youtube.com/watch?v=J4WTSXlPktY
    HKS Legamax Exhaust
    Zen Price: $929.99
    Watch A Clip!!! - http://www.youtube.com/watch?v=bBZLl-vr9gI
    Invidia Q300 Exhaust
    Zen Price: $779.99
    Watch a Clip!!! - http://www.youtube.com/watch?v=0libqva404A
    Perrin Exhaust
    Zen Price: $805.00
    Do these Exhaust Systems, no interest you let me know. I carry a wide variety of Exhaust systems. Agency Power, AMR, AMS, Apexi, APS, Blitz, Borla, Buddy Club, Greddy, Perrin, Vibrant Performance, and more!!!
    Zen Motors LLC
    Bump!
    Zen Motors LLC
    Weekend Bump!!!
    Zen Motors LLC
    Bump!
    Zen Motors LLC
    Bump!
    Zen Motors LLC
    Bump!!!
    Zen Motors LLC
    Bump for Zen!
    Zen Motors LLC
    Flowery Branch, GA
    Looks like you have alot of good products at good prices. Whats up with the military discount?
    Quote Originally Posted by bdydrpdmazda View Post
    Let me know what you need. I'll take care of my military customers. I offer discounted parts, and labor!
    Zen Motors LLC
    Just wanted to let everyone know that it is not to late to order your gifts for Christmas! Give me a call and I'll set you up something nice!
    Zen Motors LLC
