Results 1 to 30 of 30
Thread: very bad wobble from car
    ccw replicas
    kennesaw
    Default very bad wobble from car
    ok i just bought a ef sedan with a b16 swap with a b16 tranny. the problem is that when i turn the car to the right there is a loud clunking sound, and it feels like the car is limping or running over something. I replace both axels last night and it didnt change a thing. we had the car on jack stands and when you drive the car in the air and turn the wheel to the right, the whole motor starts to shake pretty damn bad. just trying to get some ideas of what it could be. im pretty mechanically inclined, im just pretty stumped right now.
    HF
    college park
    what does the carfax on the car look like was it ever hit? how is the rack and pinion on the car
    now with LSD
    Hmm....ShakaLock??
    NorthSide Red Rider
    Rack and Pinion Possibly...Ever been wrecked?
    *Edit* Oops JayDc2 has a Good Idea lol
    Quote Originally Posted by KIZDAWAY View Post
    Sounds like a date, wear some make-up cuz dis will be in HD. I'll bring da K-game, so you better be on race fuel cuz you'll need it. :boobies:
    Quote Originally Posted by Glides View Post
    This whole, "It's just the internet" is just dumb. If that's the truth then the person busting you in the face for running your mouth can say, "It's just 5 cross yo lip dude, don't take it too seriously"
    ccw replicas
    kennesaw
    never been wrecked, but its in the air right now, and i can figure out why the entire motor would shake bc of the rack and pinion. there is no load on the tires or anything, and if you remotely turn the wheel to the right it starts to shake bad
    HF
    the county
    is it shaking while driving? or just running?
    if its driving, then have you had your rotors turned?
    ccw replicas
    kennesaw
    its not rotors. i know how things work, this is the only thing that really stumped me. it feels like a bad axel, and that is what i assumed it was. so i replaced both of them last night and its still doing the same thing. i bought the car on tuesday and it was fine, now its just getting worse and i cant figure out what the fuck it is.
    HF
    the county
    maybe you somehow dropped a cylinder.
    all getting a good fire and fuel?
    www.jjspec.com Macon, Ga
    Wheel bearing possibly?
    college park
    swapped or stock motor charlie?
    now with LSD
    ccw replicas
    kennesaw
    its a b16 with b16 tranny and yes its a swapped motor, mainstream did it and i have the receipts. but its not a wheels bearing, it is a violent shake when im actually driving the car. and when its in the air and we turn the wheel to the right and the wheels are moving, then the whole motor starts to shake like crazy as well.
    HF
    the county
    just throwing it out, but maybe some bad mounts?
    ccw replicas
    kennesaw
    it cant be bc it would do that at all times if it was the mounts. but it will ONLY do it when i turn the car to the right. and it doesnt matter if its on the road, or in the air.
    HF
    college park
    i dont know why you would choose gsr axels they could be your problem ive never heard of anyone using those when doing that swap hmmm....the only thing i would suggest would be to check your rack and pinion and last choice check the rims to see if they are bent a lil that could be a issue as well.
    is there any boot grease anywhere under the wheel well?
    now with LSD
    It could be an axle binding up like he was saying.
    ccw replicas
    kennesaw
    there is no boot grease, and the person who owned the car before me said that they were gsr axels, and they fit right in, its not like this little wobble like a bent wheel. and none of them are bent, i just put them on. its a intense ass wobble that feels like the car is going fucking break itself. im waiting on eminnodagreat to call me bc he might have a little more info for me since they did the swap.
    HF
    ccw replicas
    kennesaw
    forgot to mention that its a b16A y1 tranny without lsd
    HF
    Differential possibly?
    college park
    tranny type would have nothing to do with it hmmm how is the allignment on the car like if you drive and let go of the wheel will it drift to one side.... we had the same thing with dare's crx but we changed out the rack and pinion and that went away this has me scratching my head a bit since it only does it to one side.. and no boot grease anywhere....ill show this thread to dare and see what he thinks
    now with LSD
    the county
    i think anything that it could have been, has been mentioned.
    ccw replicas
    kennesaw
    thanks guys, ive been searching pretty much all day, and i think im going to need an intermediate shaft off of a 92 teggy, bc i believe the on that is on there is the jdm b16a shaft and its about an inch too long. so ill be going to the junk yard tomorrow to figure it out.
    but yea jermaine have him direct his way here to see if he has any opinions
    HF
    cobb county
    jus a suggestion... your motor mounts
    the county
    already stated that. he said no.
    ccw replicas
    kennesaw
    no mounts are straight, i checked the obvious things already as i stated. but thanks for the help
    HF
    sorry i havent called, i have been sick as shit today, that car had that same problem with us, we replaced the axles and it went away.... but it took 3 sets, we kept getting shitty remans..
    cable tranny or hydro? but i thought I letcha know. I've had a similar problem with a crx with a full b16 motor w/cable tranny.. i swaped in and horrible shaking and vibration was coming from the drivers side, replaced the axles. same problem. and then thought maybe it was the half shaft which it was a original b16A half shaft. got some info from a buddy and told me i needed DA half shafts so I changed out the half shaft and bammm no more wobble/wobble ..
    /Oo ___A___ oO\
    |=_/_______\_=|
    ccw replicas
    kennesaw
    Quote Originally Posted by YouKnowIt
    yea i have been reading up on this on honda tech, and im going to go get a da half shaft tomorrow and well see if that helps the problem. yea its a cable y1
    its all good man, if i cant figure it out tomorrow then ill call up to mainstream and see what the fuck is going on.
    HF
    i'm pretty sure that will fix your problems 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    ccw replicas
    kennesaw
    i fucking hope so, it feels just like a blown axel, but they are brand new
    HF
    just wondering when you bought the car, was it wobbling already or it just happened??
    /Oo ___A___ oO\
    |=_/_______\_=|
    ccw replicas
    kennesaw
    just started to happen
    HF
