Results 1 to 15 of 15
Thread: WTB:VALVE SPRING COMPRESSOR
    Default WTB:VALVE SPRING COMPRESSOR
    NEED TO BORROW/BUY A VALVE SPRING COMPRESSOR FOR A B SERIES ASAP!! CALL ME OR LEAVE UR NUMBER HERE 678-462-8928
    For your tyte caR?
    Quote Originally Posted by Maniacurabus06
    The men sit down at a table, then Jesus says, 'whomever kisses me, will betray me, unless it is Mark; he's only doing it because he's queer.' LOL
    yea, changin out valve seals
    Nice, Check Autozone or something, then return it haha.
    thats the one i have, it dont work
    i will buy it from u or buy u lunch...
    Build 42% Done ACCORDPRIDE's Avatar
    In a pile a H22 parts
    might try buying the on watever210 has
    he WAS trying to sell it but not sure anymore
    pm him
    AKA HIZDAWAY
    really i dont care
    norcross
    Is the head still on the block? If it is you could use the compressed air method to keep the valves up. I had a mitsi motor and used rope in the spark plug hole. I turned the crank till the rope was smashed in there to keep the valves from falling in to the combustion chamber. Hope this helps.
    GWINNETT IS GREAT!
    ^^ NOT HELPFUL
    LOL nope it isnt....
    im gunna return the compression tester tool because the VALVES DO NOT DROP, PISTONS HOLD THEM UP...just like i thought..., just can only do the outer ones first, then inner 2 pistons...
    but now i need a valve steam seal puller, they are all stuck...
    Sent to be deleted. Later, QD.
    Quote Originally Posted by Benefit
    You should be able to pull em off with a pair of plyers, twisting a little.
    I have a valve spring tool, that is hand held, works great. Got it off the mac truck...
    roflcopter V-Spec II
    Norcross
    Then cool I can close the thread lol
