Results 1 to 19 of 19
Thread: 2009 Ferrari 599XX
    The Green Jeep STI101's Avatar
    Dunwoody
    Default 2009 Ferrari 599XX
    Check it....
    While based on the 599 GTB Fiorano with the same transaxle layout and engine type, this prototype is an extreme track car. Ferrari's engineers have carried out extensive work on the engine's combustion chambers and inlet and exhaust tracts. These modifications, combined with the fact that internal attrition has been reduced and the maximum revs have been boosted to 9,000 rpm, helped achieve the target power output of 700 hp at 9,000 rpm. Particular attention was also paid to cutting the weight of the engine unit components. This was achieved both by optimising forms - as in the new crankshaft - and adopting exclusive materials, as in the carbon-fibre used for the intake plenums. A new gearbox shift strategy cuts overall gearchange times to 60 ms.
    The 599XX is characterised by an innovative electronic concept called the "High Performance Dynamic Concept" which has been designed to get the maximum performance from the car by managing the combination of the car's mechanical limits with the potential of its electronic controls. The mechanical and electronic systems work together to get the maximum performance from the car under extreme high performance driving, for consistent lap times. The sporty handling has been improved thanks to the adoption of second generation SCM suspension system. Track usage is also made easier thanks to the new "virtual car engineer", a screen in the car that provides a real-time indication of the vehicle's efficiency.
    The 599XX's aerodynamics were honed in numerous wind tunnel test sessions with the result that the car now boasts 280 kg of downforce at 200 km/h (630 kg at 300 km/h). The front underside of the body is completely faired-in and the vents that channel hot air from the engine bay have been moved to the bonnet.
    The "Actiflow" system increases downforce and/or cuts drag depending on the car's trim cornering conditions, courtesy of the use of a porous material in the diffuser and two fans in the boot which channel the air flow from under the car out through two grilles next to the tail-lights. Winglets have been added to the rear buttresses to increase downforce. while synthetic jets have also been incorporated into the rear of the car to control and smooth the air flow and to reduce drag.
    Ferrari's engineers have also used F1-derived "doughnuts" which partly cover the brake discs and wheel rim. These have the dual function of improving both aerodynamics and brake cooling.
    In terms of the bodywork, composites and carbon-fibre have been widely used and the engineers drew on their experience in working with aluminium to reach the weight target. The development of increasingly high-performance materials has also benefited the carbon-ceramic material braking system. The brake pads are now made from carbon-fibre which means that the calipers are smaller whilst guaranteeing the same efficiency. The new racing carbon ceramic braking system also delivers shorter braking distances and is generally more efficient due to the weight saving.
    The 599XX comes with slick tyres (29/67 R19 Front and 31/71 R19 Rear) specifically developed to maximise stability in cornering and increase lateral acceleration. They are fitted to 19 x 11J wheel rims at the front and 19 x 12J at the rear.
    Attached Thumbnails Attached Thumbnails -42751-jpg   -42752-jpg   -42753-jpg
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    THAT is sex on wheels
    Dunwoody
    check out the brakes.
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    REPOST!
    Use Search.. Its your friend..
    2009 Geneva Motor Show: Ferrari 599XX
    Dunwoody
    Quote Originally Posted by Frög
    REPOST!
    Opps...
    MOST HATED
    Upstate SC/ATL
    I'm not going to lie and say I wouldn't drive it because afterall, it is a Ferrari however, I'm not a fan of its appearance.
    It's good to be boosted JennB's Avatar
    ITP
    I cannot wait to see that thing in person... my gawd... drooooooooool
    2005 Mazdaspeed MX-5 -1.8L Turbo
    xxxx mirz833's Avatar
    Duluth
    nice
    Looks like a GTR in some way.
    Vinings, GA
    Quote Originally Posted by HeLLo iM iZzY
    You mean the GTR looks like the 599 in some way
    AMERICA FUCK YEAH
    Quote Originally Posted by NewGen33
    x2..
    Daytona Beach
    Quote Originally Posted by JennB
    Um....not to be mean but you say that like it will happen.
    Car Ram Rod. Dville nismo's Avatar
    douglasville ga
    I love that car!
    ITP
    I'll gladly take that bet.
    Yeah, actually it will
    Daytona Beach
    Are you going to Italy? I had to go to Marenello to see an Enzo for the first time so...
    ITP
    I'm in Italy right now.
    I'll be at the Geneva Auto Show in just a couple of days. My ticket is in my purse.
    And I've seen 5 Enzos (No really, I'm actually serious)
    I'll post pics after the show. I'm pretty excited about it. I've seen a lot of really awesome stuff on various websites from there this year.
    chill six7teen's Avatar
    Columbus
    you better post pics after the show!! lol
    Daytona Beach
    Ah cool stuff.
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    nice as hell
