We carry Gold color stand bulbs for some one new in the forum
Brand New in Protective Boxes
GP Thunder
3500K
Plasma-Gold
Quartz Glass Bulbs
3500K Plasma Gold
Plasma Xenon Headlight Low/High Beam Bulbs/Fog Light/Running Light
Supreme Quality
Standard Wattage
H1 55W
H3 55W
H4 (9003) 55W/60W Lo/Hi Beams
H7 55W
H10 55W
H11 55W
H13 60W/55W
9004 (HB1) 45/65W Lo/Hi Beams
9005 (HB3) 65W
9006 (HB4) 55W
9007 (HB5) 55/65W Lo/Hi Beams
880 27W
Reasons that GP Thunder 3500K bulbs are the best bulbs on the market:
1, GP Thunder bulbs are made of fused quartz glass so they can produce high generating power even though they are just smaller. They have excellent heat shock-resistance and they won't be broken even though they have water on their surface when they light on. GP Thunder bulbs also prevent any damage to the lens and wiring harness because their newest design .
2, GP Thunder bulbs have a longer life because they contain Xenon and Krypton gases.
3, They have high performance quartz bulb and completely new base concept.
  • Synthesis of most successful bulbs worldwide
  • Easy to mount because of its newly designed plastic base
  • Precise fitting of bulb in base
  • Serve full range of application (fog, low beam, high beam)
GP Thunder bulbs are the best on the market ever. With 3500K degree Kelvin temperature giving you the best golden color for your car!
You can only find it here!! Nowhere else!
We are proud of bringing the best to our customers!
Actual color of our GP Thunder 3500K. H7 shown above.
Stock bulb-brown color
GP Thunder 3500K Golden Brilliant
Features:
  • Improve discrimination to objects at night
  • Color harmonized with HID lighting in effect and color temperature
  • Easy to substitute for standard halogen bulbs
  • Meets ECE R37 and DOT regulation
  • Installation is easy as 123.
  • E1, E13 certifications
  • DOT approved
Warranty:
45 day replacement warranty for defective GP Thunder bulbs only. Free replacement if under warranty.
Refund is also available if you are not completely satisfied within 10 days.
Note: Every bulb has its life, we can only provide 45 day warranty while other sellers don't have any warranty. The tested average life for GP Thunder bulbs are as following:
Please keep in mind "DO NOT" touch the bulb glass surface while installation. Your fingerprint may cause damage to the bulbs when you turn on the light.
Please check here to see if the bulbs fit your car if you are not sure and can't find it on your car's manual.
D1S D2R D2R D4S D4R Bulbs, Xenon Head Light bulbs, Interior Lights, Exterior Lights, Angel Lights, Signal Lights, Wheel Lights, Acura Honda Accessories, Motocycle Lights.
