Results 1 to 26 of 26
Thread: DSM HELP with idle surge
    JohnBobAlingAdang 88NaCivic's Avatar
    Walton Cnty
    Default DSM HELP with idle surge
    I have a problem with idle surge. Can someone help me out please! THis is what I have, I just bought a 92 Eagle talon tsi. I took my brothers Apexi BOV off his 90 AWD eclipse and put it on my talon. After installing on my car it started idle surge. I did a little looking around and found out that the external BOV can cause the idle surge. After a day or so of the GREAT sound I decided to put my stock BOV back on the problem still excites. Does anyone in the DSM world can help me out with this. The car never did idle surge before I put the BOV on. Any help would be greatly appreciated.
    Certified Gearhead 1slodsm's Avatar
    Dallas
    IAC motor could be going bad
    Check for VAC leaks also thats another cause
    Walton Cnty
    Got cha, I know that VAC leak can cause that but when I put everything back to stock I made sure that everything was snug. I will have to check it out again just to make sure! Thanks for the info 05spydergts
    North Augusta, SC
    Is it being recirculated???
    Back to being stock and slow
    Walton Cnty
    It is now! but not when I installed the Apexi
    Walton Cnty
    I thought that putting the stock BOV back on to recirculate would fix the problem but it didn't.
    North Augusta, SC
    Is it a constant surge or is it searching for idle and sometimes die?
    Walton Cnty
    Never dies, just about a 500 RPM surge.
    Boost is your friend $9ktt's Avatar
    Disgusta, GA
    Try re-setting your ECU. And make sure you did not disconnect any vac. lines.
    B
    Walton Cnty
    Yeah I found that the thermovalve Vac line was dry rotted and disconnected. The problem is that damn nipple on the thermovalve broke. Jeep/Eagle said that they couldn't even order it. So I'm now looking at blocking those vac. lines off. Any info on that $9ktt? To reset the ECU it's just disconnect the negative on the battery rite?
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    Quote Originally Posted by 88NaCivic
    Disconnect it, then plug the vac line. Problem solved.
    And yes, disconnect your ground terminal for like 5 -10 mins, then reconnect it.
    Walton Cnty
    K power I tried that last night blocking the vac. line off and resetting the ecu. NO luck still a slight idle surge. ERRrrrr that shit is pissing me oFF!
    West palm beach
    Contact GASTROKER on here, He is the man with DSM's
    North Augusta, SC
    ^^^ yeah, Mike is pretty good with his stuff. BUT he comes on this forum VERY RARELY.
    Check out GADSM.org, VFAQ.net (this site will be your best friend now that you have a DSM. I have probably read info on this site for a solid 20 hours)
    Vinman on here (mainly on GADSM.org) knows his shit inside and out. Might be easier to get in contact with. Just my .02.
    ATH GA. SRCRX's Avatar
    On the drum set!!
    trader!!
    Walton Cnty
    Motivation. Thanks man, I've been on GAdsm for a few days looking around. Found some good info!
    Walton Cnty
    Steve. Yeah,Yeah,Yeah I know!! After almost 12 years I'm ready for a change!
    Dec 2003
    Atlanta,GA
    sounds like IAC going bad,make sure the coolant is flowing threw the tb. vaccum leaks as well will cause it. and def. keep the bov recirculating if possible mine ran like a piece of horse poo when it was undone
    Ellenwood
    Hmmm...have you checked your BISS? I know when I had this issue with my 2g, it was somehow related to that. I didn't fix it personally, but the guy that bought it, brought a scan tool with him, and said it was somehow related.
    Disgusta, GA
    ^ Werd !!! I forgot about the BISS. Mine came out of the Eclipse just this week !!!
    Look on the TB and make sure that screw is still in there. They have been known to come out.
    I've ran a Greddy Type-S, HKS SSQBV, and an RFL Bov on my 2gs VTA with no idle surge.
    And spray some TB cleaner up the TB, the TPS and butterfly.
    B
    could also be the TPS sensor... :-)
    Friends come... and friends go... but Honda brothers and sisters are FOREVER
    Indecisive SOB aguynamedpat's Avatar
    In your attic
    Mike (GASTROKER) is the man when it comes to fast DSM's, but he has said he isnt the best at diagnosing OTHER people's problems. If you want good help, get with Vinman on GADSM (new site president BTW). Ive bought cars, parts, sold parts and all that with Vinny, he is good people.
    So this problem didnt happen until you swapped the BOV? It did not do this at all before?
    Quote Originally Posted by Psycho View Post
    I don't know any dentists, but I got a dremel and a handful of oxycontin. If you got $50 we can make this work.
    North Augusta, SC
    Quote Originally Posted by aguynamedpat
    repost.
    Walton Cnty
    Naw, never did it before. I found that the thermo valve vac. line was broke off. I'm pretty sure that is what is causing it to surge now that the stock BOV is back on. Also I'd like to say Guys down at MAIN STREAM did a HELL'a of job on my 3" exhaust!! Rite ON' !
    North Augusta, SC
    Awesome... I havent found you one yet.
    Send me some pics of the tsi via PM for what we were talking about before.
    Walton Cnty
    Motivation,
    I will ASAP probably this weekend, Just been Busy w/ work!
    But definitely interested !!
