Results 1 to 23 of 23
Thread: Question LSD broken?
    Norcross
    Default Question LSD broken?
    How can u tell if your LSD is broken or messed up. This is an ITR tranny. Is there any way to tell just by looking through the axle holes? Also, does anyone know symptoms of a messed up lsd... thanks in advance. reps wil b given
    If it was messed up it wouldnt move or make shit loads of nosie ,raddle,shakes, its Gear driven!
    Norcross
    so while coming off of the clutch in 1st it rattles/shakes. but no other gear... ?:\
    Norcross
    damn well if anyone can find any info on this plz help :\
    Alpharetta, Ga
    when you pop the clutch do you leave 1 or 2 black strips?...... and if its only in one gear then.... your probably looking for something specific with that ONE GEAR.... final drive is not a place to start. and in a LSD you cant look through the axle holes.... because well... its a LSD not a open diff.
    The G Spot Hero
    Norcross
    Quote Originally Posted by DirtyMechanic
    im confused with wat ur trying to say about the black strips and im talkin about where the axles go inside the tranny, you can look straight through there
    You need a tranny!
    Alpharetta, Ga
    Quote Originally Posted by j0nbunklah0m
    with a LSD you CANT look through the axle holes.... because of the LSD.... duh.... and black strips.... tires.....? omg.... go back to noob school....
    The G Spot Hero
    Norcross
    ................. so ur telling me ur not supose to be able to look through the axle holes.... and then u tell me to go back to noob school.. lmfao ok guy. lmfaoooooooo damn i ddont even kno wat to say to ur stupid ass
    the county
    after what he just said to you, i dont think there is anything you can say.
    2 black strips= both of your tires spinning.
    common sense dude.
    yes if you take out your axle if it has a pin in it then its not LSD if there isnt a pin and its open then its LSD
    Norcross
    Quote Originally Posted by Tran
    common sense dude.
    ok im not asking if i fucking have lsd.. i do.. i know i do.. wats the point...? im asking if anyone knows symptoms of a broken or damaged lsd
    Go to an area where one tire is on grass, the other on pavement (clear area, no one around) then rev it and drop the clutch, if the car turns in towards the grass rapidly, the LSD is worn out, if the car goes straight, it works, or gradually goes towards the grass, it's good.
    If you take both axles out and can see straight thru the hole you do NOT have an LSD or its broken, badly.
    BMW 750iL
    Alpharetta, Ga
    why dont you back pedal a little more.... why did you ask if you can see through the axles holes if you KNOW you have a LSD.... see noob.... go back to school... maybe shut your mouth once in a while and listen you might learn something.
    Quote Originally Posted by X-Runner
    pwnt....
    The G Spot Hero
    uh yeah dirty mech. is right about the axle hole thing. lol
    DUDE your tranny is fuked buy a new one and stop bitching
    pwnt....
    Im confused My 94 did not have a pin in the hole (you could see straight through) and it was not an LSD trans.
    BMW 750iL
    Norcross
    pwnt....
    are u fucking stupid? i said CAN U TELL IF THE LSD IS MESSED UP JUST BY LOOKING THROUGH THE AXLE HOLE.
    and IF U CAN SEE THROUGH THE AXLE HOLE ITS LSD
    http://www.ff-squad.com/tech/lsd/lsd.check.jpg <~ check that out fucking stupid bitch
    Senior Member G.C's Avatar
    Forgot
    hahahah ya got owned. think ya the one who needs to go back to school.
    :idb:
    Forgot
    besides he's not asking if he has lsd or not, he wants to know whats wrong with his tranny. so why are ya even arguing bout this.
    TOMAWAYYYYY
    :idb:
    283.5°.516&quot;(13.11mm) DirtyMechanic's Avatar
    Alpharetta, Ga
    if you know so much then why are you even asking. let alone why are you asking IA, shouldnt you be asking honda-tech or something. your first set of questions are very easy to figure out on your own. pull axles look through. then to see if it works, rev up like the ricer you are then pop the clutch and hope it doesnt slip. and see if it leaves two black strips.... your knowledge still ceases to amaze me....
    The G Spot Hero
    Norcross
    i never asked if i HAVE lsd.. i kno that i do. i only asked if u could tell if it was damaged or broken just by looking through the hole. why u keep going around the original question tryin to make me look dumb. fuckin faggot hippie bitch
