Results 1 to 15 of 15
Thread: 1988 mazda rx7 turbo II help?
    im down right fierce hadouken's Avatar
    Default 1988 mazda rx7 turbo II help?
    i was wondering if i could swap the turbo II motor out with a n/a 13b engine and swap over the turbo kit...
    and if not i was wondering what are the differences between the 13b and the 13bt
    sorry rotary newb
    Super Dave Z U L8R's Avatar
    Roswell
    not to flame you, but you can wickidpedia the differences in the motors.
    another 13bt motor is not expensive........just wait and save yourself the time, money, hassle, and wasted energy.
    my .02
    DAve
    Why? The N/A engines don't take to boost as well because htey hvae a 6 port layout instead of a 4 port. It's 4 smaller always open ports, then two auxillary ports that are exhaust-backpressure fed to open at 4K RPM, and the turbo would hamper the backpressure so they wouldn't work right, and 6 smaller ports don't flow as well as 4 bigger ports. not to mentino the N/A engine has high compression rotors so under boost they are more likely to detonate, so you'll have to tune the boost down a bit, or run 93 octane. It really isn't worth turboing an N/A when you already have the 4 port TII motor.
    thats fine thats what i expected anyway
    thx for the fax
    +reps
    no problemo
    Dec 2003
    Atlanta,GA
    yea just wait and buy another 13bt or rebuild yours!! or sell me your fc t2 for cheap! lol
    Woodstock
    Build your NA motor, mine is plenty of power for what I need.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    RotoN00b DarwinsA32's Avatar
    Lol, i'll take the T2 for my NA. A little fabrication and some new rotors will have you runnin good. look at aaron cake' s Turbo NA FC. "tina"
    Unknown
    hey i was wonderin if anyone knew a shop where they do cheap labor on rotarys. Or anybody period who knows what theyre doin. I got a 87 rx7 nonturbo with a small oil leak in the front-driver side bottom of the engine. Thanks for any info.
    G-net
    You need to go to Rx7club.com or teamfc3s.org. Not many people on here deal with rotarys. The ones that replied are about it.
    One Big Ass Mistake America
    Quote Originally Posted by FC3SADDICT
    Its a good chance its an oil cooler line leaking
    That's also near the oil pump.
    Canton
    Quote Originally Posted by SLOWR/T
    Take 90% of what you read on that forum as a grain of salt most of the people on there tend to nut swing to certain companies.
    Try not. Do or Do not.
    yeah im gonna just replace the engine with another t2 found one for pretty cheap and it seems like a good deal so thats what im gonna do =]
    TOYOTA1515
    You guys need to know al the big HP rotaries from PR uses the high comp. rotors from the N/A engines to achive the goal of 800+ whp the side housings from the 6 port engine will work for turbo prety good with the valves eliminated but not as good as a nice set of T2 or Cosmos 13b side housings.
    But let me answer your question no matter i am late cuz you already found another pandoras box, NO you just cant swap your turbo stuff to the N/A engine it is not compatible, anyway i will recomend you just to rebuilt your own engine and go with all new rebuilt kit from mazda, buying used rotary engine is 99.7% always a waste of $$$$
