Results 1 to 14 of 14
Thread: h22a
    Banned MSTANGSALEEN's Avatar
    Default h22a
    Trade my 9.8sec 1/4 mile yzf750rr for this.90 crx with a 95 h22a in it and here is what he had to say about it.
    The car is a stick and the motor has around 65000 on it and around 1500 on the built bottom end.
    Engine:
    Dc sports header
    Weisco 12.5:1comp pistons
    eagle rods
    all new bearings and seals
    balanced and blue printed
    Custom ported fuel rail with mustang 5.0 injectors
    stage 3 clutch adn 7lb. flywheel
    Bronze painted valve cover
    New timing belt, plugs,and wires
    All custom mounts
    and custom alternator bracket
    Tanabe racing medallion catback
    car has custom cross member and cnc traction bars
    Suspension:
    90-93 DA integra axles aswell as suspension
    Coilovers
    Disk brakes all around w/ slotted rotors on rear. New brakes all around metallic.
    Exterior:
    Mugen style kit
    stock wheels
    car is painted yellow
    Interior:
    JDM sir seats
    dash has no rips or tears
    custom short shifter
    The only thing with the interior is there are no panels.
    The only thing the car needs to run is a fuel pump I jusst invested so much I am broke now. Car is an easy 11 sec car when it gets the fuel pump. So let me know what you think of it.
    Senior Member 99SI's Avatar
    Jackson
    Sounds like a scary proposition unless you know the guy personally and see receipts for not only parts but labor as well. It doesn't run but only needs a fuel pump then it'll be running 11's sounds way too risky for me. I don't care much for buying cars or engines that have already been built unless it was from a reputable shop that knows what they are doing. If I were you and wanted to do a hatch I would sell the bike find you a decent shell and do your own build. You may end up spending a bit more but you will be infinitely more satisfied with having done what YOU wanted to do rather than picking up someone elses dream project.
    So IF I DID go with it,,do I get a 90 crx walbro fuel pump or a h22 fuel pump?
    Jackson
    I would say that if everything that has been done to it you would be better served with the walbro.
    He later writes I can get the car to crank by pooring fuel directly into the intake manifold then the car dies after that fuel burns off. I have put new injectors in it and checked everything else. You can not hear the fuel pum cut on when you turn the key. I have had 2 techs. tell me that it was the fuel pump. Also I have a car trailer for this weekend only my bro might can haul it for us if you can give him some gas money he is alittle fun about gas now that it is so high. You have got to understand him on that. we can work the transport out let me know if you wanna come check it out.
    well this is the same car that DIET HONDA had for sale on IL. it was NOT A BUILT MOTOR at the time. it was STOCK and they couldnt get it to run either cause of the wiring differences. MAKE SURE YOU CHECK IT OUT and make sure it has what he claims it has. ask for receipts
    Its from highcomp
    ok well it sounds eerily similar to the same car Diet Honda was selling. so check it out and make sure it has what he claims.
    Hmm I know he said its yellow, but I am not sure of all I am checking for.I have had nissans and what not so dont know about honda motors
    Quote Originally Posted by nizmo240
    ask for receipts
    pull the spark plugs out and check to see if the pistons are forged or not.
    Ask who built the motor. cause you CANNOT run forged internals on a H22 FRE block unless its sleeved. so the block had to have been at least sleeved.
    if I pull the plugs out how can I tell if its forged?
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    why not just get the fuel pump and put it in... that would be like cutting your losses.. if its straight after then, buy it if not.... at least you didnt take a thousands of dollars hit.
    yea just dont have $100 to get one
    To 942JZGTE 93H22ACX's Avatar
    just put a stock fuel pump in it to see if it runs...
    i doubt that motor will run 11's especially with an exhaust and no head work. Unless the car makes like 230+whp and weiths 1700lbs with driver
    94 Supra= 500rwhp
