Results 1 to 2 of 2
Thread: Anyone local know 1.8t Audi????
    DurtyDubs pebojelly's Avatar
    Villa Rica
    Default Anyone local know 1.8t Audi????
    I have an A4 and I am trying to see if anyone local can remap the ecu and tune the car.
    If not I am trying to find the factory turbo and mani to run until I can gather up the rest of the crap I need for the 57mm turbo I have.
    Its an XS power that was rebuilt using garret seals and bearing so its ready to play.
    I also have a XS power mani and WG with a 8psi spring but I was told the amount of air I am going to be moving will cause the motor to detonate on the stock tune.
    The psi will not be the problem but the amount of air will cause it to lean up way to much.
    Anyone know if this is 100% accurate?
    I could use a tiny bit of help.
    my momma's house
    I'm chillin with my VDub friends, and they're telling me your going to have to check into Revo and Unitronic turbo builds. That way you can find what they're running and hopefully get them to send you the map. Before you start that car, your gunna need a base map. Hit up Scott at Assit Motorsports.
    Trend settin'
