Thread: Idle Problem????
    Dec 2008
    Default Idle Problem????
    I have a 2000 Honda Civic Si wit a B20 vtec swap, B16 head, and when the car is idling, the rpm's will rise up a little then go back down, at a slow pace, and after a while, it will go back down to a 1000, and when i rev it a little it will start again. When it starts, its idling at 1500 when it does it, and i have actually seen it happen at a 1000 one time.
    Now i have checked all hoses to the intake manifold and every thing is tightly put in, all sensors are plugged in, and the engine light is not on, so i have no idea what it is.
    PLEASE i need some help!!!
    aye bro .:Stirfry:.'s Avatar
    take off the IAVC on your intake mani, and give that bit a good cleaning with some purple power, break cleaner, or any other degreaser..
    ATL DAsquad Member #9
    Southside Ridin HATCH
    spray throttle body clean all around... maybe you will find a VAC leak
    Dec 2008
    Quote Originally Posted by Black4DrEK
    I have already done that.
    i'm guessing it's not tuned. what ecu are you running since there isn't a stock b20vtec ecu.
    Dec 2008
    It is tuned by Mainstream Performance, i bought an aftermarket one.
    Dec 2008
    Senior Member steedracer's Avatar
    winder
    IAC valve
    if it was tuned there then i tuned it.
    how long ago was it that it was tuned? did anything (i mean anything) change since it was tuned?
