Results 1 to 10 of 10
Thread: 96 civic starting problem
    Default 96 civic starting problem
    i have a 96 civic which i had to change the engine in which i put in a d15b which i changed everything to obd2 but now car wont start... i have fuel and spark everythings hooked up. turns over but back fires what is wrong!!!
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Timing?
    if u did the conversion correct. your timing is off.
    i drive slow im_hung's Avatar
    location, location
    do you have the CKP hooked up?
    if it backfired your timing is off
    1,3,4,2
    Sep 2008
    lithonia
    crank sensor? i had a similar problem and it was my crank sensor.
    Slimm
    how do i check the crank sensor
    location, location
    CKP (crank position sensor) located in the dizzy on obd1 d-series motors. on obd2 it should be located by the crank pulley.
    North Augusta, SC
    I'll agree with the ones on timing is off... Happened to mine too. It's your quickest and cheapest fix, also.
    Back to being stock and slow
    aye bro .:Stirfry:.'s Avatar
    also wont hurt to check the rotor button in the dizzy:.. if its broken ,
    had that happen to a friend
    ATL DAsquad Member #9
