Results 1 to 10 of 10
Thread: ENG CHECK LIGHT CODE
    J.R
    Down South
    Default ENG CHECK LIGHT CODE
    I connected the wire under tha passenger side dash
    (the self diagnostic trouble code wires)
    and the engine check light flashs seven times
    repeats a fast seven blinks pauses then another seven
    and another seven, i counted this seven time then
    fig it was a CODE 7
    code 7= throttle angle (tps)
    How do i stop this ?
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Quote Originally Posted by NOCLUE
    You get a new Throttle position sensor.
    J.R
    Down South
    well wont that one just read the same, what is the prob in the first place ?
    EF Squad
    the problem usually lies in the TPS electrical which u really cant do much but to get the whole thing replaced. u can get TPS for pretty cheap for about 20 bucks used from any d or b series.
    J.R
    Down South
    and everything is ok i can drive safely right, nothing is in harm
    J.R
    Down South
    So nothing is wrong
    so new tps = Light gone no problems?
    why did it come on in the 1 place
    Middle Ga.
    So nothing is wrong
    Correct. That's what's throwing a trouble code, so that's your problem. And something obviously failed inside our tps that's on your car now.
    J.R
    Down South
    Quote Originally Posted by 93_DA
    Thanks for the 101
    turbos
    yea and they dont screw out unless ur handy so try and just find a new throttle body with all sensors attached. http://www.d-series.org is a place where you can usually pic one up for next to nothing
    TOO BIG
    J.R
    Down South
    Is it safe to drive till i get this
