Results 1 to 25 of 25
Thread: Anyone know UNIX shell scripting?
    Default Anyone know UNIX shell scripting?
    So, I'm sitting here trying to start an assignment and have no idea where to start.
    Implement a UNIX shell program (ld) that will list only directories in the directories on the command line. A command with no arguments assumes the current directory.
    Anyone know how to do this?
    - IA Mgmt
    Shell scripting is gravy, what shell are you using.. bash ?
    *turns on linux server to get the correct command line argument*
    Yeah, if that's what Ubuntu shell is. I don't know jack shit about Linux.
    - IA Mgmt
    Yes ubuntu uses bash by default.
    Seems like the simplest way to do this would be
    #!/bin/bash
    ls-D
    then save it as ld
    chmod 755 ld
    should be good to go.
    then you could also save the ld shell script into /bin and it would be global.
    Do I just write it to a text file and save as .sh?
    - IA Mgmt
    Yep that would work. But youve gotta make sure to chmod 755 to make it executable. You should really practice command line file editing.. most purists use Vi but im very partial to pico (its easier for quick edits since there isnt a ton of key mapping memorizations.)
    edit: you could more easily chmod +x the script also to preserve correct owner permissions.
    Have you ever worked with .bat files on windows/dos ?
    alright so how do I specify the directory to open and it won't let me save it to bin
    - IA Mgmt
    Ah we need to pass an argument then, okay try this instead:
    #/bin/bash
    ls -D $1
    $1 is the first passed argument string.
    So then to execute the shell script you would do like:
    ./ld.sh /root
    which would list hte directory contents of /root etc.
    you wont be able to save to /bin unless you do it as root (sudo on ubuntu)
    and I use VI in class but ubuntu's vi is a BITCH
    - IA Mgmt
    Ignore than i even mentioned putting it in /bin, im sure your instructor doesnt intend for you to do that. you would also need to remove .sh from the file name.
    Yea VI has its advantages in the programming world but its a little bit aggravating to learn LOL. Ubuntu uses the same VI as every other posix compliant o/s.
    Well for some reason I can't use the arrow keys, cant use backspace etc.. in my VI
    Also I'm getting error: ./ld.sh: line 2: ls-D: command not found
    - IA Mgmt
    there is a space between ls and -D.
    LS is the command to list directory contents. -D is an argument to LS that only lists directories.
    wow, it works, you are the man. Please bath yourself in my reps, for it is all I have to give
    - IA Mgmt
    LOL not a prob man.
    Shell scripts are really easy once u kinda get the hang of how they work.
    They are basically just an automated list of commands you would normally type at the prompt. Then shell scripts also allow for you to add additional options like passing arguments (like we did with $1 as the first string) and if/then type arguments etc. They work very similiar to batch files with dos.
    Gotcha, problem is my Prof doesn't teach us SHIT. We have to learn all of this by ourselves (that's what he told us today) plus c and c++.
    I'm a java master but this stuff confuses the hell outta me
    - IA Mgmt
    Oh yeah don't forget about man pages and --help arguments.
    for instance, i wasnt sure how to only list directories within a directory so i typed:
    ls --help
    which helped me to find the -D argument to list only directories.
    man pages are short for manual.. aka
    man ls
    or man vi
    Well have fun with C, its heavy shit especially compared to shell scripting. its over my head lol. i enjoy *nix networking etc and shell scripting can help to automate things quite a bit.
    Well we just finished c, which I still don't understand. C++ is easier though
    - IA Mgmt
    LOL well thats cool. Hit me up with any more questions.
    aight man, thanks again
    - IA Mgmt
    Woodstock
    what class is this, I wanna take it.
    I am a year into linux, like a month into basic script. I would love to learn more.
    Honda RC51 SP1
    Yoshi RS-3 Cans
    520 Conversion
    Clip Ons
    Race Tech Fork Kit
    Quote Originally Posted by Blitanicle99
    It's not really a Linux class, just System Software. My professor just happens to like linux.
    - IA Mgmt
