Results 1 to 21 of 21
Thread: Changing TRanny fluid
    Default Changing TRanny fluid
    Just wondering what fluid should i use for a ITR tranny. i got 1 quart of GM Syncromesh and 2 quarts of 10w-30 motor oil. Can i use motor oil? or do i have to use gear oil. and the 2 quarts of 10w-30 motor oil is advanced auto parts brand. lol
    It's all about JDM.
    CA to GA
    use oem Honda Transmission fluid...sold at dealer...
    Gm Synchromesh or OEM fluid
    I wouldn't mix the two fluids.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Quote Originally Posted by gsrteg
    Nawwwwwww that's a horrible idea...
    i drive slow im_hung's Avatar
    location, location
    genuine Honda MTF only... that is if u still want to keep ur tranny...
    southside ATL
    using this penzoil gm syncromesh. any good?
    :noitacoL
    Honda MTF
    Looks like this:
    ^^^ Get that.
    the reason why im using gm syncromesh because i heard it does wonders, and i have a grind in 3rd gear. will it still be good to use that penzoil gm syncromesh?
    Just use the synchromesh/oil combo.
    I personally run straight 80w90 in my trannys, makes it shift like butter....(after warm up)
    JDM TYTE AnthonyF's Avatar
    Hondas can temperamental to certain fluids. I would run OEM honda fluids.
    -Ant.
    The Carbon Fibered R6
    honda mtf or synthetic 10w30. i've only used synthetic 10/30 in my trans and it has 140k+ miles on it. the owners manual says honda mtf or synthetic 10w30.
    Back from R&D Land
    Back from R&D Land
    Honda MTF or Redline MTL. If the trans doesn't see a ton of stress, the OEM stuff is pretty good. If you have a high trq setup and the shear wear on the fluid is high, the Redline stuff is great to resist this.
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    location, location
    Honda MTF
    Looks like this:
    ^^^ Get that.
    ^^ thats the old stuff... the new one has a green label
    i just got some today... fckin 7.88 a qt... prices went up...
    Screw the owners manual and I have used GM Syncromesh for about 9 years without any issues!!!!
    Either GM mesh with a 10w30
    or OEM fluid
    it will take 2 quarts dont over fill!
    im going to buy the 2 quarts of friction modified gm syncromesh and another quart of the regular gm syncromesh. so 2.3 quarts to fill.
    It will take 2 quarts and you dont need the Friction Modified your LSD isnt clutch style its Gear to gear!
    1010011010 Atlblkz06's Avatar
    Hell
    Watch out though, some MTs like the Tremec TR6060 use ATF. Why do they do that anyway?
    Quote Originally Posted by Atlblkz06
    We are talking about a HONDA they use motor OIL
    and the reason why is because some trannys uses Brass,and other metals that can only use certain fluids or it can eat the brass an damage the trannys...So certain fluids is NOTED
    just changed my fluid. still have a grind in 3rd..
