Results 1 to 26 of 26
Thread: 97 Vortec 4.3
    Default 97 Vortec 4.3
    Ive got a 97 4.3 Vortec engine from a 97 Blazer, blown head gasket and low oil pressure. Long block with oil pan, maybe intake too.
    Needs rebuilding. $100 as is or I will have it rebuilt for you.
    Vin/block code posted in the A.M. with pics.
    $20
    BMW 750iL
    Comes as shown pretty much.
    BMW 750iL
    Someone needs a core!!!!
    BMW 750iL
    Woodstock
    How much work would it be to bolt that in a 88 s-10? It had a 2.8 or 2.9 V6 in it before.
    BTW I know I'll need an ECU for it. Just need to know if it'll be a direct drop in or need to change mounts and such.
    Have to change the mounts, exhuast and trans.
    BMW 750iL
    GA Member
    Cumming, GA
    Do you know if this engine is the newer Vortec engine as opposed to the older Vortec engines? If so, I will ask my dad if he wants to buy it for his S10.
    I have no clue what your asking. It is from a 97 Blazer. It is a 97 model.
    BMW 750iL
    GA Member
    Cumming, GA
    There were a couple different engines available in the S10's and other chevy trucks and vans with the 4.3L. What kind of Blazer was it (what trim model)? That may be able to help a little. The main thing that was changed is the heads. The newer 4.3L engines heads flowed much better than the older 4.3's.
    No clue, trim level will have no effect on this engine.
    BMW 750iL
    I used to know all this stuff but I have forgotten so much about the TBI/Vortec engines since moving on to Toyotas.
    BMW 750iL
    UP UP! Gotta go, come get it!
    BMW 750iL
    Up again, make offer. Any trades, anything! Something, its gotta go.
    BMW 750iL
    Apr 2009
    if it was from a 97 im sure it was a vortec. they came out in 94. my 94 blazer had a 4.3 vortec in it stock.
    I said its a Vortec engine.
    BMW 750iL
    Bump. $20!
    BMW 750iL
    do u know if anything was wrong with the spider.
    Worked great.
    BMW 750iL
    Kennesaw, GA
    Its 20 dollers!! just buy it damnt!
    Oh the spider and dizzy is missing.
    BMW 750iL
    Quote Originally Posted by SouthrnStyle
    ok u mind your business.
    Quote Originally Posted by X-Runner
    yah i needed the spider. i was going to trash the rest less a few other parts for spares.
    Marine ForgottenSoL's Avatar
    Quote Originally Posted by 600 Double R View Post
    I'm pretty sure that Chevrolet came out with the "Vortec" engines in 1988, however they were not called Vortec till 1994.
    Where you located
    Quote Originally Posted by ForgottenSoL View Post
    They were not Vortecs back in 88. They were TBI swirl port heads.
    Quote Originally Posted by 81911SC View Post
    Where you located
    Its long gone man.
    Thanks for the 6 month bump.
    Closing then.
