Results 1 to 5 of 5
Thread: i have no idea?
    Just A SOHC DEL_SLOFTW's Avatar
    Peach state
    Default i have no idea?
    Ok so my car has been running extreamly great and then will spit and sputter then just die, even if left at an idle for about ten min. it will die.
    When i crank it sometimes the rpm needle goes crazy but the engine does nothing, and othere times ill be cruising at 2500, or 3g and it will jump up or drop a little and then just die and sometimes make a weird noise.
    If anyone could help thank you
    Peach state
    Anyone hae any idea?
    Im thinking fuel pump
    Souf Wess ATL
    o2 sensor? IACV?
    the duckster
    Rome
    X2 on iacv
    ill come over and help you clean the bitch and shit sometime this week
    Quote Originally Posted by LaotianAsn4
    o2 sensor? IACV?
    Race Ready Developments Member #5
    Rome Crew
    the tach wigging out makes me think ignition. do you have aftermarket ignition parts (msd, non honda wires/cap/rotor, non ngk plugs)? if it's totally stock swap in a known good dist and see if it goes away. if you have msd and aren't making 500whp+ then it isn't nec anyway (swap back to stock) and problem solved.
