Results 1 to 16 of 16
Thread: 91 integra auto to manual wiring
    Cobb/Cherokee County
    Default 91 integra auto to manual wiring
    need to know what i have to do with the wiring. help me please
    Back from R&D Land
    Back from R&D Land
    Are you just doing the auto to manual in the same OBD series.....1991? Or are you converting up to OBD1? What ecu are you going to be running?
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    auto to manual obd0 no staying obd0 gunna be runnin pr4 5spd
    SwiperNoSwiping!!
    Go to Autozone, etc. and get a Haynes manual, ALL wiring information will be in the back of that book in more detail than what can be provided over the internet....
    u remind me of a wigger !
    ///M :) wannab20hatch's Avatar
    Gainesville
    all you have to do as far as wiring is wire up for reverse lights if you want them. and wire in the switch.(makes the ignition think its in park all the time so you can start it.) i did the same swap in 2 of my hatches and helped a buddy do his DA. I never wired up the rev lights.
    if you do want to wire them though i believe its the green and yellow wire together for the P switch.
    what about if i originally had a manual car and im using the auto harness??? got any ideas?
    Gainesville
    would you use the auto harness in a manual car?
    yeah id try to make it work since im ignorant cant be that much different its basically like the reg. auto to manual swap
    Gainesville
    the only difference in the harness is the park switch so either will work. and thats inside the car by the shifter
    chill six7teen's Avatar
    Columbus
    how about the speed sensor wiring? (sorry for a somewhat thread jack)
    i just did a auto-manual in my 92 civic and cant get my speedometer to work..
    all good siz7teen
    youve been repped wannab20hatch!
    warner robins
    Quote Originally Posted by six7teen
    you dont have to rewire the speed sensor it should work
    JJSPEC.COM
    warner robins
    JJSPEC.COM
    Columbus
    well i kept the automatic wiring harness.. and the speed sensor plug has three wires going into it, but the speed sensor is a two prong... and my speedometer doesnt work...
    Gainesville
    search on honda-tech. the obd1 cars are a little harder to convert.
    Gainesville
    Quote Originally Posted by GaGen2Teg
    all good siz7teen
    thanks man just let me know if you need anything else.
