Results 1 to 22 of 22
Thread: Automatic car stalling? wtf...
    Unpainted EM1 Zhu's Avatar
    Default Automatic car stalling? wtf...
    Hi, so I have a friend who's car is like a 1995 automatic. The car will have a rough idle and sounds like it wants to stall out. Even when it's been driven, the car sometimes stalls at a standstill! I don't understand what's happening, my guess it the transmission is out of wack, but I wouldn't know how to fix it. At high speeds the engine does fine, but it's when it's standing still is when it has problems. Turning on heat or A/C makes the problem worse. What could be the problem? and what would the solution be? Thanks for any help!
    WTB: Driver's Side Sunvisor for 96-00 Civic
    Newnan
    learn to english
    Quote Originally Posted by ChuckNorris
    tcc was my guess also
    I see... Thanks I'll look into it. the only thing that doesn't match up is that it doesn't throw a CEL though. Plus it's unstable when it's in park also.
    Quote Originally Posted by Zhu962
    I see... Thanks I'll look into it. the only thing that doesn't match up is the it doesn't throw a CEL though. Plus it's unstable when it's in park also.
    i can bet money that there is a pending code there.
    A 95 will be OBD1
    BMW 750iL
    Quote Originally Posted by X-Runner
    A 95 will be OBD1
    lol didnt realize he put a year.
    The Deep South
    check your catalytic converter make sure its not clogged.
    Cool, I appreciate all the help. can anyone point me to a reputable tranny shop for mercedes?
    You need to fix your running problem, and then move to the transmission if there is even a problem with it.
    ^^^ Agree sounds like a tune up issue or timing
    I bought a car because the guy said the tranny was bad, it was a 99 civic ex auto...
    bought the car for 350.00 bucks and it was very clean car near mint...
    got it home checked it over and the CEL was off but had a code random misfire .Checked it out an had a bad Distr rotor button , install a new cap an rotor ran like a champ and shifted fine...But when it was running or every now and then caused the tranny to act up!
    So I got a 4500 car for 380 bucks and sold it for 4100...... Sucks I know this stuff and he didnt but isnt my fault!
    So the reason for my story is check your engine and make sure everything is fine an running like a champ and then if it still acts weird check the tranny out...But I think you don't have a tranny issue at this time...Best of luck Joshua
    I agree. I bought my 90 F-150 for $1000 because it had a bad fuel pump apparently... well the safety cut off got tripped Then it shuddered bad when shifting, was a miss-fire issue.
    BMW 750iL
    i drive slow im_hung's Avatar
    location, location
    to see if its your tranny or not, try to put it in park and see how it runs. if it idles fine then you know its a drivetrain issue...
    6th Gear Junkie Andr3w's Avatar
    Carrollton, GA
    Idle Air Sensor?
    -2002 Subaru Impreza WRX Wagon
    -2004 Nissan Sentra SE-R Spec V *boosted* (parting out)
    Quote Originally Posted by Nismo062
    Idle Air Sensor?
    WTF is that?
    You mean Idle air control valve?
    What about his struts? I hear that will cause this too
