Results 1 to 15 of 15
Thread: 1/5th Scale RC Dodge Viper GASOLINE powered
    Default 1/5th Scale RC Dodge Viper GASOLINE powered
    Well its time to move on and let my pride and joy go. This is a 6 month old HARM Sr-1. Its RTR minus your transmitter. Its got a 75mhz Futaba FM receiver in it with the failsafe built in. The car is pretty modified with a SOLO racing engine for it, instead of the regular 23cc Zenoah engine. It runs off of a gas/oil mixture so there are no issues with tuning it like a nitro car. Just pour the gas in it and start it and go, its got a weedeater engine essentially. Will run for about 45 minutes on a tank of fuel. Comes with a really nice looking blue dodge viper body. Very fast, but pretty easy to control. Car is almost 3 feet long!!!! If you want the biggest most badass rc car to show up your friends with, this is it!!! Will do close to 50MPH. Doesnt sound like much, but the fact is this car weighs 22lbs and is almost 3 feet long. Its a land missle. Parts for it are easliy obtained online.
    The car kit costs 775 dollars + 350 for teh body + 250 for racing engine + 100 for electronics = 1475 spent on this car. Its in really great shape, not perfect but not beat all to hell either. Asking 500 OBO
    Details of the SR-1 Chassis
    The motor support of the SR-1 is also the connection between rear axle and front construction. By that stable chassis construction and high crash safety is achieved.
    The front axle comes stock with stabilizer bar. Toe-out, caster and camber are adjustable. The rear axle is also equipped with stabilizer. Toe-in, toe width and camber are adjustable. The transmission bracket made of alloy guarantees stable motor mounting and heat removal.
    Delivery condition
    The SR-1 is delivered completely pre-mounted. All screws are fixed with Loctite. The chassis delivered are all measured and adjusted with a basic setup. This enables the driver to get first impression and to gain experience with the new chassis right away without having problems through building or setup mistakes. First of all, of course the radio has to be build in and ride height needs to be checked. The ride height can be changed easily through adjustment of the damper springs.
    The equipment of the SR-1
    stable double chassis construction
    competition dampers 2004
    easy motor mounting
    motor support in alloy
    rear brake
    Zenoah-Motor
    3 chamber tuning pipe
    alloy gear carrier
    24 teeth alloy gear
    compatible to H.A.R.M. alloy parts
    and much more....
    Measurements
    Measurements + Weight
    Wheelbase: 535 mm
    Length: 890 mm
    Width: 395 mm
    Weight: 7,5 - 9,5 kg
    white power!!!!!! .....1
    JDM TYTE AnthonyF's Avatar
    bump for my boi and an easy engine to start!
    -Ant.
    The Carbon Fibered R6
    i need ae86 parts canadianrcis's Avatar
    marietta
    shits crazy fast in person. bad ass car too.
    hachi roku groove
    Still Here LQQKITZME's Avatar
    Roswell
    Looks fun as hell
    View the world through a dogs eyes, if you can't screw it or eat it, pi$$ on it and walk away.
    IA Member Gwb's Avatar
    Snellville
    bump for a kick ass large scale
    It really is all of the above statements. lol. If you do burnout it will leave marks and if you hold it the tires will smoke.
    Man that shitt looks mean!
    At almost 3 feet long it is!
    Bump for a hella fun car
    marietta
    can i go drive it into a curb or something chris?
    hachi roku groove
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    NEED VIDS!!!
    VIDS would be nice!
    http://www.youtube.com/watch?v=sIFtakGisu0
    http://www.youtube.com/watch?v=Mbf7yFRKHxc
    If you buy a front brake kit you can sit there and power brake it too. Like in the second video
    ttt
    bump for offers?
