Thread: d16 USDM swap into 89 crx si
    Certified Gearhead Le_Stat's Avatar
    MACon G.A.
    Question d16A1 USDM swap into 89 crx si
    i was wondering if this swap will fit right in or will i have to spend alot of time and money to make it fit from what i read i can take the mounts off my old motor and put them on this one and it should bolt right up,,,,,
    ohh yea its a D16A1
    Warner robins ,Ga
    what kind of d16?
    MACon G.A.
    the one ur boy has 4 sale
    straight ninja mode EuroTra$h's Avatar
    canton
    it will bolt straight up im almost positive its the same as the DOHC ZC and that bolted right up in my 91 hatch back so it should wotk
    Warner robins ,Ga
    Quote Originally Posted by Le_Stat
    its a pretty easy swap. i posted a link about the swap on his sale thread.
    \m/>_<\m/ dorin48's Avatar
    Canton
    NO. A d16a1 is the brown top zc out of the integra. It uses different mounts and makes less power than the other dohc zc's. www.thezcr.com is a good resource.
    Warner robins ,Ga
    Quote Originally Posted by dorin48
    and your point?
    Canton
    OP was asking if it should bolt right up. No it wont. Other people in this thread made it clear that they weren't 100% positive with the exception of you lol. I am giving my thoughts thats all. Also a lot of people are constantly mislead into believing that the A1 is the same as a DOHC ZC, A8, or A9 which it isnt.
    Warner robins ,Ga
    you are correct. but its not hard to do the swap.
    ++reps for you sir.
    Canton
    Yay i did good! lol back at you.
    MACon G.A.
    yea i kno its not the zc or else i would have put it up on the first post lol
    chill six7teen's Avatar
    Columbus
    i believe that it will bolt up if you have all the mounts.. i have a ZC swap out of a crx and got it to bolt into my eg civic perfectly!! only thing is to make sure you change this bracket...
