Thread: jdm h23 injectors on a b16?
    about this far.
    Default jdm h23 injectors on a b16?
    i was looking to upgrade my injectors before i get my car tuned, but i heard you can run jdm h23 injectors. but i wanted to know if you could run the obd 1 h23 injectors on the obd 1 wiring and not have to do anything, is this true?
    reps for help!
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Senior Member Nang's Avatar
    you need to run a resistor box i believe
    Project DX
    yea you can run them but pick up a resitor box
    DOHC NO-TEC
    about this far.
    where do i have to plug in the box? and where can i get one?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    You're gonna have to wire in the resistor box, they don't plug into the civic harness since their injectors are of the Saturated type while the prelude ones are peak and hold injectors. You can get one off a prelude of an old 88-91 civic with mpfi or a 90-93 integra. Just need the box and plug.
    my brother put h22 injectors in his d16 engine and they plugged right in and it ran good.but he didnt have to wire in a box
    you should always check the resistance of the injector with a digitl meter. 2-4 ohm=use resistorbox, 11-14 ohm=no resistorbox. if you have the lower impedance injectors w/o a resistorbox or higher resistance injectors w/ a resistorbox you'll eventually burn out the injector drivers in the ecu=not good.
    SNOW WHITE dexsohcvtec's Avatar
    what kind of car cuz the da's come with the box
    Quote Originally Posted by kpowerhatch
