Results 1 to 23 of 23
Thread: Help w/ Emission
    EF Squad
    Default Help w/ Emission
    Okay so i went to get my emission done today after i got my swap done onto the crx with a b20. Yes i have a cat and full catback. Overall, i failed the NOx test for both.
    Here is my result:
    25/25 Test:
    Reading: Allowed:
    HC ppm 40 160
    CO % 0.00 0.90
    NOx ppm 2282 1179
    50/15 Test:
    Reading: Allowed:
    HC ppm 45 166
    CO % 0.00 0.93
    NOx ppm 3187 1304
    EF Squad
    any help plz??
    Stone Mountain
    if N0x failed it could be your exaust gas recirculating valve. the only thing it does is control you n0x levels. if that doesnt work. contact 350zftw
    Oct 2003
    Quote Originally Posted by Major Motion
    Nice try but none of the B series Honda engines come with an EGR. Besides, even if it had EGR and it worked, the numbers would still be high. The main purpose of the EGR is to assist in reducing the NOx, not control it.
    The issue with this car would be the catalytic converter not oxidizing the way it should. How big is the converter/exhaust and is it still in the stock position?
    EF Squad
    I tried to look up pics where my EGR is located but cant find it for the b20b which was swapped onto my crx. And y contact 350zftw?
    EF Squad
    the converter is from magnaflow which i ordered online and is universal:
    Inlet/Outlet Size: 2.5"
    Overall Length: 13"
    Body Length: 9"
    Width: 6 1/2"
    Height: 4"
    OBD 1 & 2 Approved!
    As for the the catback i got a skunk 2 mega power specifically for a 88-91 crx (d series)used. So i took it to muffler shop to get some flanges and get it custom since the header is from a b series and the catback is from a d series.
    Oct 2003
    Quote Originally Posted by Tensa_Zanget
    Overall Length: 13"
    Body Length: 9"
    Width: 6 1/2"
    Height: 4"
    OBD 1 & 2 Approved!
    The converter is too large for that engine as far as emissions go. If you can get it to pass with the same converter, it's gonna have to be from the lowest gear allowed. The cat isn't flowing enough gas from that 2.0L at those engine speeds for it to work properly. Your best bet is to retard the shit out of the timing and retry. If that don't work, you need to install a smaller converter, possibly a 2 inch converter, 2.25 max.
    EF Squad
    But that is the same cat that i got that my friend recommended me. He also got a crx with a ls/vtec and he mange to pass his emission test..besides if its the cat wouldnt i fail the HC ppm and CO %?
    Oct 2003
    Nope. According to your emissions numbers, you have a lazy O2 sensor judging by the CO numbers. You want them to be anywhere near .20 or lower. You may wanna consider changing that sometime. But even then, that would show up under HC's meaning that the failing O2 sensor is causing the computer to dump fuel. But your HC's are in a controllable range so that's not part of the problem. The converter you bought is just like your stock converter; it's a 3 way catalyst. It has to get hot enough to burn off any unburned fuel (HC) and CO. It has to eliminate or seriously reduce the levels of NOx. Retard your timing and try it again. But ask for a pretest so you don't waste your second (free) test.
    EF Squad
    As u were saying about my O2 sensor, I dont have the O2 sensor installed at the moment after the swap cus before, i had a d series and its running a one wire o2 sensor so now i need a 4 wire O2 sensor. Surprisingly i still pass the other portion of the test w/o the O2 sensor. As u were saying about letting the cat warm up, i drove the car for about 10-15mins max due to no tag at the moment but will that really helps? As for the timinig i just got the timing light from a friend but i dont know what is the standard degree for a b20b. Also when u speak of timing which one ur talking about ignition timing or the other timing?
    Oct 2003
    Ignition.
    EF Squad
    Ignition.
    What would be the standard timinig for a b20b or right spec i should time it too. What abou the O2 sensr could that also cause an incrase in the NOx?
    btw thxs for all ur input
    Stone Mountain
    sorry. i dont know anything about honda motors. i just know that is why my Z wouldnt pass emissions. ive got headers, and the feed to the EGR valve was only from one cylinder when it needed to be from 3. there just wasnt enough pressure to open/close the valve. and 350zftw got my car to pass. hes really good with emissions stuff
    EF Squad
    Oh i see. thxs for the help though. Does 350z do emission himself or he just knows stuff about emission?
    Stone Mountain
    he does them himself
    small yall putting this mans name out there all in the open. shit like that take to PMs.
    Stone Mountain
    lol nothing illegal dude. i mean he just knows his shit. he can tell you whats wrong and fix it. he got me goin in no time for a good price. all legally. haha but yea i see where that could have been taken wrong
    EF Squad
    HAHAHA for a second i thought the same thing! I was kind of puzzled at what no mo honda was saying too. Where is this place of his at?
    cool just wanted to that clear.
    EF Squad
    i tried pming 350zftw but havent got any reply from him yet. In the meantime anyone else know wat to do to reduce the NOx? I will be gtting a timing light soon from a friend, when i do i will try retarding the timing. Any good walk through to retard the timinig?
    EF Squad
    please io need help!
    EF Squad
    Btw, how u determine if u got a 3 way or 2 way cat that blackshine is refering to?
    EF Squad
    ttt
