Results 1 to 14 of 14
Thread: EG6 D16 Turbo Problems
    Default EG6 D16 TURBO PROBLEMS
    got a friend that just turboed his car today, and for some reason, the BOV wasnt going off, theres enough pressure and everything is tightened up...and we tried 3 different BOV's and nothing...
    anothe problem was it smokes white smoke out the exhaust like crazy, theres no oil leak, and the turbo is spooling fine, could it be the worn out head gaskets? i believe he said he didnt rebuild the motor before he turbo'd it...
    ill post pics/videos of it tomorrow
    1991 Acura Integra
    1998 Toyota Corolla
    Made in BRASIL junior_tm's Avatar
    Brasil
    you should have posted this on the forced induction btw
    sorry i cant help you with your problem
    ToTaLMaDNe$$
    Yeah we roll and we ride
    In control, we don't stop
    We gonna glow where we drive
    Let you know we on top
    Warner robins ,Ga
    Quote Originally Posted by MrBoostedCRX
    got a friend that just turboed his car today, and for some reason, the BOF wasnt going off, theres enough pressure and everything is tightened up...and we tried 3 different BOF's and nothing...
    its because he needs a blow off valve [aka BOV] not blow off f___?
    Quote Originally Posted by junior_tm
    is it because i gave to little information? he begged me to put this on here because he doesnt have time/money to take it to shop...
    and its my first thread that has been misplaced...mods can u help me out? or should i make another thread?
    1991 Acura Integra
    1998 Toyota Corolla
    Quote Originally Posted by xdavidscenex
    the V is right next to the F, cut me some slack
    1991 Acura Integra
    1998 Toyota Corolla
    Warner robins ,Ga
    just making sure man...i thought he had some super jdm BOF. sorry.
    anyways...check the vaccum lines.
    ok thanks man, so head gasket and vaccum lines...got it
    1991 Acura Integra
    1998 Toyota Corolla
    so whats a BOF and this isnt the forced induction section.
    White smoke? That's more then likely headgasket.
    How many miles does the engine have now?
    Should've rebuilt it before going turbo.
    known as Charles
    White smoke after turbo install is TURBO. Blown headgaskets normally steam instead of smoke out the exhaust and will normally pressurize the cooling system. As for BOV where is the vac line from the bov hooked up to the motor at. Need to check the drain like for turbo and maybe put a restrictor in the oil supply line.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Quote Originally Posted by HeLLo iM iZzY
    100k+ and i know he should of, he said it was rebuilt 5 months ago...but i told him he should of changed things again thanks for the tip, reps
    Quote Originally Posted by Main Stream
    ok...ill tell him right now, hes in line buying the stuff he needs, and ill ask him where its connected to..its a t3/t4 fat turbo on a little engine...
    1991 Acura Integra
    1998 Toyota Corolla
    roflcopter V-Spec II
    Norcross
    Moved.
    warner robins
    make sure the bov is ran to a vac. source and not a boost only source.
    JJSPEC.COM
    i'm already seeing a problem. smoke? let me guess, it's not tuned and probably on a basemap if the ecu is even chipped. right?
    there are not too many places you can tap the vac source on a d-series so just t off the fpr.
