Results 1 to 19 of 19
Thread: hatch rear disc conversion question
    Atl
    Default hatch rear disc conversion question
    ok i own a 92 civic hatchback dx and just completed the integra front and rear disc conversion on it (whoa one hell of a party that was). my main question is since i did this do i need to upgrade the brake master cylinder to a civic si one or a after market one. i think the piston size on all the bmc are the same but i could be wrong. Can i keep the stock bmc that came factory on the dx with drums?? or should i upgrade.. thanks my current bmc is in good shape and does not leak
    Also wat muffler looks the best on hatches cuz when i did the upgrade i put a set of blox lca on it and my knockoff obx twinloop muffler is blocking the pass. side lca u can only see one lol
    credibility and reputation
    Hwy 315
    your brake master cylinder will be fine - if you're looking for your rear discs to actually improve your braking instead of just looking nice - then you're going to need to change out the proportioning valve.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    your moms house
    Quote Originally Posted by se7en
    -jonathan
    werd grab the proportioning valve and it will make a big difference in performance
    Atl
    but which pv should i get?? si im assuming..
    for it all the work right. u will need to get the a RS DA non ABS master cylinder an the booster, and 40/40 proportioning valve from a EG SI or a del sol. while your at it u might as well get ls/gsr front and rear sway bars.
    turbos
    ^^^^ yep
    TOO BIG
    Atl
    bet as far as the sway bars i think i might solid instead of hollow sway bars.. what u think? comptech? eibach?
    Acworth
    I agree with all- did the same swap on my civic- HAD to upgrade prop valve otherwise it feels like crap.
    it will say 3040 or 4040 on the cylinder- it is easy to see on the firewall. hint- its easy to do but more annoying that you would think with traditional hand tools since you cant turn the bolt that far.
    also upgraded at the same time to stainless lines and that made it feel real good.
    Quote Originally Posted by HatchHero
    i had the oem on mines for at least 2 years loved. i ever did anything with the car to that made me feel i had to upgrade. so i left them alone.
    LAWRENCEVILLE
    i have a 40/40 pp valve
    Hella stock member!
    college park
    ^^^what dont you have lol
    now with LSD
    LAWRENCEVILLE
    and i wish i didnt have it all
    Hella stock member!
    Quote Originally Posted by silversol
    lol the money would be better.
    chill six7teen's Avatar
    Columbus
    http://www.progressauto.com/products.../productID/573
    this is the sway bar i have! 100% worth the money.. i'd actually pay more if it cost more! you can adjust oversteer/understeer, and also the height of it's mounting so it wont hit the exhaust and such.. it also works as a rear tie bar as well!!
    only complaint ive ever heard out of this is that after a while of hard driving with it, it could possibly rip out your subframe.. so just order a subframe brace for it
    Hwy 315
    Quote Originally Posted by six7teen
    ...hahahaha, how much did you pay for it?
    -jonathan
    [/URL]
    Columbus
    -jonathan
    and i'd do it again!!
    Atl
    wow reps for u. i didnt know they made them like that. that one would de awsome for h22 delslow. THANKS MAN im savin money for that
    Atl
    cool it would be alot cheaper that route. that progress one is like 250. im really goona consider that one on my sol wit dat bulldog motor in the frontgonna order a civic si pv
    Columbus
    yeah man... only problem i have had with it so far was assembly/installation.. lol. assembly probably took an hour and a half and install another hour and a half.. it is VERY complex, but worth it!!
