Results 1 to 11 of 11
Thread: big problem!!!!!!
    driftoritos ftw!!!
    Default big problem!!!!!!
    Ok Guys I have a problem today when driving my car it started going crazy. At about 2700 rpm the tach just goes crazy and jumps all over the place and the car bogs a little but if you punch it hard the tach eventually straightens back out at around 4k and the car takes off like a rocket (well a slow rocket with a stock d16a6 that is). I think it is the Ignitor (Ignition control module or ICM)
    Any thoughts?
    Thanks in advance-- Justin
    Quote Originally Posted by 91eflx
    Maybe this guy could help:
    Later, QD.
    driftoritos ftw!!!
    yeah he knows all
    “The only thing that could make free gumballs better is if I could get the quarter out of that machine”…03Rcode
    Canton
    Ground?
    Try not. Do or Do not.
    driftoritos ftw!!!
    i know the ground between the vc and frame is good i still need to check the others
    what time is lunch?
    woodstock
    check to make sure you plugs are tight going into your dizzy.
    Like you said it might be the ignitor module, If you have a spare replace it and check.
    My spare one got put into my other car cause of erratic issues with bogg down, weak spark. Replaced the module and all was good.
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    I think your muffler bearing is bad, Or it could possibly be that you need to rotate the air in your tires...Hope this helps!!!
    Acworth
    Lol^^^ Maybe its your coolant, check to see if its green or orange its its not one of those two then you might as well burn the car.
    Repent or Perish jdm_crx_man's Avatar
    McDonough
    hmmm.....any check engine codes
    He Alone Is God...Prepare For His VICTORY!!!
    driftoritos ftw!!!
    yeah its throwing a code for the vss and eld but thats it i checked all of the plugs in the dizzy nothing so im pretty sure its the ignitor ive heard they had a recall on them because of the failure rate
    driftoritos ftw!!!
    ok i feel like an idiot i took out all of the plugs putem back in and it runs fine at the moment ill update again tomorrow if its still good i didnt drive it long today
