Results 1 to 21 of 21
Thread: i need a power estimate from the pros
    revolution big mac's Avatar
    Default i need a power estimate from the pros
    how much power would i expect to see out of this set up with a good dyno tune
    b16a head
    b18b1 block
    s80 ls tranny
    ross racing low compression pistons 81.5mm 9.1
    eagle rods
    micro polished crank with stock bearing
    kms block guard 25+ psi
    itr manifold
    ram stage 3 clutch
    rev hard cast iron manifold
    t3 t4 50 trim turbo
    delta2 turbonetics weastgate
    turbo xs boost controler
    xs power intercooler and piping
    3 in doen pipe
    3 in exhaust
    450cc injector dsm blue tops
    crx resistor box
    inline pro oil return line
    hks high flow trpe r oil pump
    chipped p72
    ngk colder plugs and wires
    Northwest Georgia
    what size turbo?
    160 hp and a whole lotta noise
    1991 Acura Integra
    1998 Toyota Corolla
    50 trim t3/t4
    come on...
    Northwest Georgia
    right but what size turbo?
    hmmmm idk man the turbo is on the car. what would be the most common size
    Northwest Georgia
    what brand of turbo is it, was this a bolt on kit?
    turbonetics? Garrett?
    it will probably make like 450 maxed out.
    for all we know it could be an s366 that can support 700hp
    those are 51 trims depending on whose calculating.
    im not sure man i will have to see later. so how much power would you estimate the car to have?
    you'll probably max the injectors out before the turbo. 450cc inj are good for 275-300whp unless you crank the fuel pressure way up and not worth it. plan on upgrading the injectors. also, i didn't see arp head studs...get those too. don't waste the $$ on the turboxs boost control. either get an electronic boost control or tap the wastegate from the turbo outlet so you can just drop a vac-t or 2 on there to up the boost.
    dc5
    ATL, GA
    get some rc 750ccs man
    you would need to consider other things as well... you will definately max the injectors, think you may need an aftermarket fpr and you would do better off with some GSR cams, and just doing a poor mans type r build. or get a golden eagle sandwitch plate to do the oil line for the VTEC head. adj cam gears are a must...
    research first
    Newnan
    19403 hp definitely.
    learn to english
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    ^^This. Reps for honesty.
    back in the days i heard that u can make the same hp as the cc of the injector. Which mean ud be able to make 450hp. Then later i talked to scotty and he said it may be possible but ud have to jack the fuel pressure way up. I say u should run ur turbo and then get a big turbo and get it tuned to see how much more pwr u can actually make by just switching turbos alone. R & D bitches!!!!!
    Northwest Georgia
    i didnt realize there was 450cc INJ on the list lol. yeah more like 325?
    750's usually blackout in the mid to upper 400's on normal pressures.
    Well I already have this setup. I just need 550 injector a 255 welbro fuel pump and 3bar. Not to mention a beter tune from Scott at mainstream
    up
    just going by your size injectors! i'll say you'll max out prolly around 300-375
    /Oo ___A___ oO\
    |=_/_______\_=|
    Back from R&D Land
    Back from R&D Land
    Not to mention....LS tranny FTL. As others have said, injectors are your shortest stick.
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    Certified Gearhead miro_gt's Avatar
    your injectors will limit you to about 275whp.
    when you upgrade those, your turbo will limit you to about 400whp if it uses .63 housing. It if it's with .48 then it will limit to about 350whp.
    you may want to upgrade the radiator
