Thread: remove PCV system?
    Yeah its a 4 door
    Default remove PCV system?
    would it be alright to remove the PCV system??? well not remove it but not connect it??? I have heard the PCV can be the culprit of H22's burning oil. I've already tried a catch can but it doesnt help. could i just put a breather filter on the end of the PCV valve similar to the valve cover breather and plug the nipple on the intake manifold????
    PCV is an important part of an engine. IMO
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    X2 why would you want to remove it for?
    100% agreed
    Thats why almost every car has one, but there are some that dont too, I rather have one in my car!
    ive worked on a few cars with the system removed. they are crap. pcv setup removed will affect a lot of things.
    Quote Originally Posted by CB7tuner
    So you're losing oil some where and just don't know where? Did the catch can have much oil in it when you were using it? The can prevents the oil from going into the intake manifold and eventually on top of the cylinder where it gets burned. If that didn't stop it from losing oil then it's burning it somewhere else, most likely the rings are toast...
    YEAH! bRiAnMcIvIcS's Avatar
    Very true.
    Quote Originally Posted by bRiAnMcIvIcS
    Very true.
    oops, meant top of cylinder wall/top of piston.
    No.
